HKS 3037s Spool Up
Old May 15, 2005 | 08:08 PM
  #31
wspy's Avatar
woobos, I have the HKS gt3037s kit and on a 2.0L with ported head and 272's. stock ECU flashed with -5deg on the timing (don't ask).
Was getting full boost 22psi in 1st and 2nd at 5500rpms 3rd at about 5000.
Changed to the .73 A/R and stroked to 2.3L. Now full boost at around 4-4500.
You'll much prefer the .73!
Old May 15, 2005 | 08:47 PM
  #32
woobos's Avatar
Thanks Wspy
I ordered the .73 exhaust housing. My timing during spoolup is low. I also had it tuned lean during spool up trying to heat things up. Have you heard of other 3037 (w/ .87) owners getting full boost by 4200rpm on a 2.0 block? I'm trying to troubleshoot here. Do you the our head ports are too big? Any suggestions will be appreciated
Ben
Old May 16, 2005 | 03:22 PM
  #33
woobos's Avatar
Anyone else with input?
Old May 16, 2005 | 03:28 PM
  #34
evo8r's Avatar
Originally Posted by woobos
Hi guys
I'll like to get feedback from those who have used the 3037. I'll like to know at what rpms do you achieve 22psi on a 2.0l block.
Thanks
Ben
i have full boost by 4500rpm 25psi
Old May 16, 2005 | 03:30 PM
  #35
woobos's Avatar
Hi
Is that spool up with a .63 or .82 A/R?
Old May 16, 2005 | 03:33 PM
  #36
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
get the .63 backside and you will be golden
Old May 16, 2005 | 03:56 PM
  #37
evo8r's Avatar
Hi
.63
Old May 16, 2005 | 07:02 PM
  #38
housedj's Avatar
Originally Posted by strongbear0
There is no way that anyone is getting full spool on a stock evo motor with a t67 @ 300rpm's. So they know so much more than all the tuners in the US or are they using an antilag system? The t67 cars I have been in with aem ems don't make full spool, 21psi, till around 5000. So they should be able to get a gt25r to reach full spool under 3000 since the spool up on the 35r is faster than the spool up on a t67? Whatever. I love it when people post up wild facts without proof. So I gues people like David Buschur/ AMS/ RNR/ and vishnu are all doing it wrong because their 35r's are not spooling till 4800-5000 on a 2.0l. Why don't you post up a data log with engine load and engine speed so we can see some proof.
the proof will be here soon. also FYI, the guy is using a MOTEC M800 PRO ECU which is still to date makes the most power. he also attained 340whp on a mustang dyno w/93 octane on a stock EVO motor w/no mods.
Old May 17, 2005 | 07:59 AM
  #39
wspy's Avatar
Thanks Wspy
Ben
The head ports should'nt be a problem, that .87 A/R on the original is just way too big for the 2.0L. One could try to get the spoolup quicker by some extensive tuning of timing etc. with a stand-alone ecu but I don't think that it would make too much of a diff.
The .73 that you ordered will spool quicker and it won't trouble your top end, unless you plan to shift at 9000rpm . The .63 would spool even quicker!
You'll be ok with the .73 and if need be you can add some timing in the lower rpm range to spool things quicker
Old May 17, 2005 | 05:47 PM
  #40
woobos's Avatar
Wspy
You just made me feel so much better. I thought there must be something wrong with my setup when I'm hearing pple spool up @ 4000-4200rpms.
Thanks
Old May 17, 2005 | 09:54 PM
  #41
Doogie Howser's Avatar
dyno graph or ban
Old May 19, 2005 | 08:26 AM
  #42
wspy's Avatar
Wspy
Thanks
No problem man
Oh BTW you should check with Garry down at SpeedInjected in Hallandale 954 214 7481 he'll set you right!
Mark
Old May 19, 2005 | 09:08 AM
  #43
love2burn420's Avatar
I get full spool at about 4200 rpm.
Old May 19, 2005 | 09:21 AM
  #44
But im only pushing 20 psi
Old May 19, 2005 | 09:23 AM
  #45
And over 400 to the wheel on pump gas is good numbers for these turbos, I thought?
