4G63 Question
Old May 11, 2005 | 09:48 PM
timzcat's Avatar
4G63 Question
Did 1st Gen and 2nd Gen 4G63 engines come as 85mm Bore and 88mm Stroke?
I need someone who knows the answer. It seems if the rods fit all then the bores would be the same since the displacement is.
Old May 11, 2005 | 10:41 PM
timzcat's Avatar
bump for a DSM'er
Old May 11, 2005 | 10:45 PM
DrEvo's Avatar
Yeahup you are correct, the usual eclipse/talon;1g/2g 2.3L stroker kit is going to 102mm stroke (88mm stock) and 86mm bore (85mm stock). Though I am not sure if this is what AMS is using for the Evo, but most likely they are. Hope this helps.
