Boost Leak Test Question
Old May 12, 2005 | 12:25 PM
prowler's Avatar
There is a local shop that has a machine that is designed to test for boost leaks. It makes 'smoke', therefore, making it a lot easier to spot the leak.
However, it only produces over 1psi of pressure. So my question is; would 1 psi be enough to spot a boost leak, or do i need to make my own and push 20 psi through to find the leaks?
Thanks
Old May 12, 2005 | 12:45 PM
Widebandphillip's Avatar
20-24psi would be real nice. You wouldn't be able to see anything with 1 psi.
Old May 12, 2005 | 02:00 PM
GOKOU's Avatar
The smoke idea is but I doubt you will see anything at 1psi.
How are you guys able to get 20-24 psi? Mines went to at most 15 psi and started to leak down. Did you cap the upper intercooler pipe? Was the engine at TDC?
Old May 12, 2005 | 02:03 PM
jid2's Avatar
I got mine up to 20 psi, but I had to cap all sorts of stuff off. I tested with the IC pipes on the throttle body and found some tiny leaks. Then I capped the IC pipe at the throttle body and the BOV and tested from the compressor.
1 psi is worthless.
