What do i need with cams and gears?
Old May 12, 2005 | 01:50 PM
evo7racer's Avatar
Question What do i need with cams and gears?
Hi, I ordered my cams (Hks 264/272) with Hks cam gears. Do i need a new timing and a shaft belt? If I only need one of those belts or none please let me know so I can use the money could be used for something else. Also which brand belt would you use if so?
Old May 12, 2005 | 04:39 PM
qbbraveheart's Avatar
I would get some ARP head studs also
Old May 12, 2005 | 05:13 PM
Ted B's Avatar
You have everything you need to make a cam change and get the most out of it, so save your money.
Old May 12, 2005 | 05:16 PM
bigcountry's Avatar
im wondring too what about gaskets an seals??
Old May 12, 2005 | 05:24 PM
Ted B's Avatar
AFAIK, everything is reusable. A cam timing tool from a Mitsu dealer is not a bad idea if you're going to tackle the job yourself.
Here is a good step-by-step guide:
http://www.evomoto.com/tech_info.php...3_6&tech_id=18
Old May 12, 2005 | 05:30 PM
robert5995's Avatar
Racer -
Put the cams in and enjoy them. They made a huge difference for me. On the drive home, up a canyon road, I basically went up a gear for the whole drive. Leave everything else the same.
Old May 12, 2005 | 05:42 PM
Evoisdream's Avatar
timeing belt tensioner tol if you are installing and a lil bit of gasket in a tube for the valve cover..... other then that nothing headstuds are for high PSI not cams...
Old May 12, 2005 | 06:13 PM
j8's Avatar
j8
It is a good idea to change your cam seals, they are pretty cheap. You can pick them up at your dealer.
Old May 12, 2005 | 06:17 PM
03BREvo8's Avatar
When ever you take off the timing belt you should replace it.. you should also get a new balance shaft belt and valve cover gasket and 2 new cam seals. youll need a engine jack due to the fact that you have to take off 2 motor mounts and lift the engine at an angle.. its roughly a 7hr job to replace everything.. the cam runner bolts should be tq'd to 20lb just rem that...
Old May 12, 2005 | 06:18 PM
scherejs's Avatar
i had always heard that you should change timing belt unless you have under 10,000 miles on it when changing cams. i don't know how much truth that holds, but it seems to be the norm in the dsm community. personally i'd prolly just change the seals like said before. i got mine for $14 online.
Old May 12, 2005 | 06:19 PM
plokivos's Avatar
word~ most important. timing belt attention.
Old May 12, 2005 | 06:24 PM
scherejs's Avatar
also you will want to bleed the lifters.
Old May 12, 2005 | 09:39 PM
timzcat's Avatar
If no one noticed he has an evo VII so it probably has some miles on it.
Put both belts on it and use Mitsu parts.
Ideally replace the tensioner. Check the tensioner and idler pulley and replace if even questionable. Couple hundred now or a couple grand later, your choice.
You don't need the tensioner tool (threaded rod). You really need the tensioner pulley tool.
Old May 13, 2005 | 06:31 AM
Ted B's Avatar
Good point. I saw the "VII" in his signature, but I ASSume everyone here is speaking of an EVO VIII by default unless indicated otherwise.
Old May 13, 2005 | 06:35 AM
03BREvo8's Avatar
You got the seals for 14.. i bought them for 9 (4.50x2) total @ NAPA
