UPgrade Intank Pump ?????????
Old May 16, 2005 | 05:07 PM
lhtevo's Avatar
Looking for more than a Walbroro pump but still intank design. Looking to support 600whp or so without the old sump system
I plan to run -6 lines , but just with an intank pump.
Thanks guys.
Old May 17, 2005 | 05:28 AM
lhtevo's Avatar
Nobody ?
Old May 17, 2005 | 09:00 AM
bolsen's Avatar
The simple answer is no one knows.
AMS has an aftermarket fuel setup, but it's big $$. And it's not intank.
As for the walbro pump, who knows. I plan on being the same HP as you, but I'm going to retain the stock lines up to the engine bay. The only mod that I'm going to make is I'm going to run a direct 12v feed to the pump so I can get the most power to it I can.
Old May 17, 2005 | 09:18 AM
JVELA's Avatar
Put two walbros on the tank. A lot of work but it works fine. I made 612 whp with that.
Old May 17, 2005 | 09:27 AM
LogicPerformanc's Avatar
in-tank pump capacity
Buschur talks about the capability of different pumps/ line configurations https://www.evolutionm.net/forums/sh...4&page=2&pp=15
page 2 a little over half way down
Old May 17, 2005 | 10:12 AM
evoviiiyou's Avatar
Call Tym @ (440)724-8495 he has this knowledge. www.switzerperformanceinnovation.com
Old May 18, 2005 | 05:13 AM
lhtevo's Avatar
Thanks for the replys .
I'm still figuring out which pump/combo to use.
I might just "pop for the full size" and get the aeromotive monster.
Old May 18, 2005 | 07:21 AM
bolsen's Avatar
You could always just opt for an external pump? Might be a medium between the two... and if it doesn't work, just go with the big setup?
