Installed cams. Need help!!
Old May 18, 2005 | 01:53 AM
EvoFoLife's Avatar
I installed my cams today, took a lot of time and made sure that I did everything right. Put it all back together and then started car... No problems sound great no CEL or anything. I took it for a spin and drove it for like a half an hour, no problems. Then my service engine soon light came on?! I checked it and I got a cam shaft angle sensor error. Did I screw something up, or did i not put the sensor on right. Is this normal? Would a flash fix it? Sorry for all of the questions, just need help. Oh yeah, and the cams were HKS 264/272. Thanks.
Old May 18, 2005 | 02:06 AM
Compjoc's Avatar
you chould find out why its throwing a CEL but if its running good, odds are you just need a reflash.
Old May 18, 2005 | 02:08 AM
yokomo's Avatar
It may have thrown the code because your dynoflash is not set up for those bigger cams you just put in. You may need another flashing, I see you don't have fuel management equipment. I think that you should since you're running all that fuel to the motor. But that's my two cents.
Old May 18, 2005 | 02:18 AM
EvoFoLife's Avatar
I checked the CEL and the error was a cam shaft angle sensor error. Not sure exactly what the code was.
Old May 18, 2005 | 02:25 AM
Wicked's Avatar
You might have put that sensor in 180 degrees backwards...?
Old May 18, 2005 | 02:28 AM
Compjoc's Avatar
i bet you just need a new reflash for the cams.
Old May 18, 2005 | 02:46 AM
Widebandphillip's Avatar
the cel has nothing to do with the flash. Where are you getting this? Anyway, you probably screwed the cam angle sensor.
Old May 18, 2005 | 02:50 AM
Wicked's Avatar
I think so also, it can go in 2 ways, one of which is incorrect... i bet if you turned the sensor 180 degrees it would be fine.
Old May 18, 2005 | 05:41 AM
Evil_1's Avatar
What they said above. Angle sensor maybe be the culprit. I installed cams on mine and no cel.
Old May 18, 2005 | 05:46 AM
Curt@MrLed's Avatar
Former Vendor
need a flash, hahaha.. take the cam sensor out check it over carefully, check the wires the plug.. and if there is no prob, try rotating it 180... but if you were 180 out now the car would not run that good...
Old May 18, 2005 | 07:55 AM
jid2's Avatar
It's not the flash, you screwed up the cam position sensor. Did you get a through the mail flash for the cams yet? I would be careful running your custom tune with the cams. Didn't you also put an intake on since the custom tune? Be careful!
Old May 18, 2005 | 10:44 AM
nickracer9's Avatar
check to see if the bolt that holds it on came loose.
Old May 18, 2005 | 04:13 PM
EvoFoLife's Avatar
I think I put the sensor in the correct position. The diagram showed the big vein on the bottom right. At a 45 degree angle. How else could I have screwed up the sensor?
Old May 18, 2005 | 05:50 PM
EvoFoLife's Avatar
bump. Anyone else know of what might be wrong. I need a solution quick?
Old May 18, 2005 | 06:07 PM
nickracer9's Avatar
you sure the bolt thats holding it onto the cam is tight?
