T-bolt clamps on stock IC pipes?
Old May 23, 2005 | 08:28 PM
mooreboost's Avatar
Has anyone run T-bolt clamps on stock IC piping? Any benefit to this?
Old May 23, 2005 | 08:31 PM
bigjhoney's Avatar
I was gonna get some put on the first time my uicp fell off. Only benefit I see is it not popping off, I would say do it if your running higher boost.
Old May 23, 2005 | 08:33 PM
mooreboost's Avatar
Im only running 20lbs, but I have popped them off a few times.
Old May 23, 2005 | 11:26 PM
Evoisdream's Avatar
the thier is for sure a benifit if u have poped them off it wont happen after u get them
Old May 24, 2005 | 12:11 AM
Compjoc's Avatar
I run 20 psi and have spiked 25 psi on stock IC pipes and clamps, never had them pop off.
Old May 24, 2005 | 04:02 AM
Widebandphillip's Avatar
ditto, i put them on right after i had trouble keeping the ic pipe on the throttle body. I'm sure it'll take as much boost as i can throw at it.
Old May 24, 2005 | 06:10 AM
cleanevo's Avatar
I have a full set of T bolt clamps and samco hoses It gives you that good feeling when you are be bad
Old May 24, 2005 | 06:26 AM
GOKOU's Avatar
I suggest you invest in some t-blot clamps.
Old May 24, 2005 | 06:30 AM
Silencer's Avatar
So who sells them in the correct stock sizes?
Old May 24, 2005 | 06:34 AM
GOKOU's Avatar
For the intercooler pipe you can get it from Napa (2.5") 7051531
, 2.75" for the throttle body,7051532.
http://www.napaonline.com/cgi-bin/n...88&prmenbr=5806
Lower pipe is 2.25". Try ebay.
I went thru a lot of sizes to get the correct ones.
Old May 24, 2005 | 07:24 AM
skiracer's Avatar
You can get them at Road Race as well. They "should" know which size will fit your Evo:
http://www.roadraceengineering.com/hoseandclamps.htm
Old May 24, 2005 | 08:46 AM
LancerEVOmann's Avatar
Dude, get them. My upper IC pipes kept blowing off with the stock C clamps, got the T clamps hasn't blown off at all.
Old May 24, 2005 | 08:50 AM
skiracer's Avatar
Think of the Tbolt clamps as cheap insurance...
Old May 24, 2005 | 09:30 AM
binsquared's Avatar
I got my Helix IC piping and for some reason my Tbolts dont fit the upper IC piping...can still slide them loose even once tightened...im forced to used the stock clamps
Old May 24, 2005 | 09:46 AM
skiracer's Avatar
Road Race also has bigger/stronger clamps if T-Bolts don't work for you. That's what i currently have on my car and i have no problems.
