way to test oxygen sensor ?
Old May 25, 2005 | 07:49 PM
chinto's Avatar
i just got an error code from my front o2 sensor sayn that my car is running lean this is after i had a bad cat and it replaced handt run with turbo for a few weeks cuz it was causing soo much back preasure.
any way was wondering if there was a way to test the sensor with like a ohm or a multi guage
thanks for the input
actually had two codes
one saying faulty main sensor then the other one saying the car was running lean.
thanks for the help
i tryed resetting the code drove it for about 2 miles and it came back.
Old May 26, 2005 | 12:48 PM
chinto's Avatar
bump
nother question as well
is my car going to be hurt because the o2 sensor is bad or will it just run rich
thanks
Old May 26, 2005 | 12:56 PM
webguy330i's Avatar
It's not gonna just run rich if it's already running lean. Sounds like some other issue than just the o2 sensor... have you thought about buying a new o2 sensor and pluggin it in?
Old May 26, 2005 | 01:01 PM
chinto's Avatar
new o2 sensor looks like its 200+ bucks and no where has them in stock iv been tryn to find one
i think the lean code was grabed as the sensor went out when i reset it the next code i got was just a bad sensor but im not sure why im askn
Old May 26, 2005 | 01:53 PM
chinto's Avatar
also the lean code could be because of the bad cat i had and not being able to run with out boost and i didnt reset the ecu after mitsu replaced the cat for the computer to relearn its fuel
mitsu probably just cleared the bad cat code
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
illogicalmind
Apr 30, 2015 03:58 AM
08evo_x
Oct 2, 2014 07:38 PM
opitkz
57
Jun 14, 2013 10:05 AM
