Problem: P0300 Random Misfire at idle on a daily basis.
Old May 31, 2005 | 06:51 PM
j8's Avatar
j8
I have the same problem with my car. It only seems to throw the code at idle. I noticed it after installing my cams. I also am hoping to find a solution to this problem. After it throws the code the idle seems to go to sh**. It starts to get rough. Are you experencing this also?
Old May 31, 2005 | 08:19 PM
Tim@AMSperformance's Avatar
A br8es plug is just like a bpr8es except that it doesnt have a projected tip. People use those plugs when really hig boost or nitrous is used. I still dont think that the plugs are your problem
Old Jun 1, 2005 | 09:17 PM
SlowCar's Avatar
Originally Posted by ct9a gsr
Were you throwing the codes while driving like most other ppl are... or at idle like I am? I'm wondering if my issue is different from most other people's issues...
the 0300 codes come on randomly...sometimes while i'm driving.....sometimes immediately after cold start....sometimes at the light.
Old Jun 3, 2005 | 07:04 AM
El Boricua's Avatar
Curious, I started to get the p0300 code after the custom flash, but the cam where replace in that occasion also, so I don't know if it is due to the cams or the custom flash..
Old Jun 3, 2005 | 07:08 AM
nhsean69's Avatar
2003 has a TSB for a reflash to solve the problem, just had it done on mine. I was getting random P0300 codes and now no more!! Not sure what year your car is but, Good Luck
Old Jun 3, 2005 | 07:41 AM
El Boricua's Avatar
My car is a 2003 also.. where did you solve the problem..? at the dealer..?
The thing is that if they fix this I will loose the custom flash, and I will have to send the ECU for another re-flash, my only issue is the time I will spend without my car.
Thanks,
Miguel
Old Jun 3, 2005 | 08:14 AM
KazzEvo8's Avatar
There are a few threads on this problem. What I'm hearing is:
1) There is more than one "update" to the firmware and not all dealerships have the latest.
2) There may be dealerships that will flash the ECU off-the-car for a nominal fee
In the meantime I'm strongly considering the CReader OBDII device for sale on eBay recommended in threads by a member here...
Old Jun 3, 2005 | 08:21 AM
Ev0ikon's Avatar
Cool
Originally Posted by KazzEvo8
And what makes you think that this will resolve the issue??
This is what I did to fix the same problem on my car. I have been over 15,000 miles without the P0300 popping up since I did that.
Old Jun 4, 2005 | 02:28 PM
ct9a gsr's Avatar
I believe my car was having this problem before I was tuned... but can't exactly remember when it started. It's started to misfire very rarely at high rpms now... but oftenly at idle still. I want to try any other fixes besides getting the dealer reflash then paying s/h to have my ecu reflashed back to it's previous map on top of the dealer flash.
What are the disadvantages or side-effects from gapping plugs too tight? I know if plugs aren't gapped tight enough, it could cause misfires... is this also true if plugs are gapped too tight? Does anyone have a knowledgable opinion on what heat range I should be using on my setup w/ the methanol? and a suggest gap? Any other suggestions on how to fix this problem?
Old Jun 5, 2005 | 07:18 AM
Ted B's Avatar
Don't waste your time by changing anything that is working properly, and don't get the dealer reflash. You'll spend time and money, and you probably won't fix the glitch.
Go to Ebay and get a "CReader" OBDII scanner. Plug it in to the OBDII port and tuck it under the dash. Leave it plugged in, and you'll never get the PO300 misfire again.
Old Jun 5, 2005 | 08:21 AM
SwiftEVO's Avatar
I started getting that code to. I had my ecu reflashed at the dealership and have not had a problem for the last 3000 miles. Oh and I have cams too.
--Josh
Old Mar 24, 2006 | 10:28 PM
Ev0ikon's Avatar
Will this Creader erase other codes too or just the P0300?
Old Mar 24, 2006 | 10:39 PM
kErViOsVIII's Avatar
it will erase all codes
Old Mar 25, 2006 | 12:07 PM
G20's Avatar
G20
Then it may do more harm than good since you're loosing the bad condition notification feature of the ECU. So there's trade-off.
Old Mar 25, 2006 | 12:37 PM
KazzEvo8's Avatar
I run a C-Reader myself and watch the display when I get a light just to make sure it reads P0300 before it clears ... I use a strip of velcro which uses the nearby screw on the bottom section of the dash so it sits right there staring up at me all the time so I can read it.
