TC "o" ring?
Old Jun 1, 2005 | 08:11 AM
bolsen's Avatar
TC "o" ring?
Reading another thread, what exactly is the TC O ring? Is it the lubed "ring" above the shaft? What's the story with this?
Old Jun 1, 2005 | 08:23 AM
instigator's Avatar
It is a big O ring that wraps around the part of the TC that slides in to the tranny. My stock one was mangled and was leaking after a clutch swap. This time I found a replacement at an auto store and hoped it would fix it and it is still leaking. My factory replacement should be in today, so hopefully it will fix the leak.
Old Jun 1, 2005 | 08:39 AM
bolsen's Avatar
hmmm, I should prob take it back off and reinspect it. I didn't grease it up or anything.
Old Jun 1, 2005 | 09:59 AM
instigator's Avatar
Yeah. Order a new one before taking it apart. It is only like $1.50 and that way you can just put a new one on while you have it apart. I didn't lube mine the first time and it must have pinched. This time i used a thicker smaller diameter o ring and lubed it up wll and it still leaked. At least I only have to pull a few things to replace it.
Old Jun 1, 2005 | 10:02 AM
GOKOU's Avatar
Props to ya cuz some of you make it sound like it's as easy as a oil change.
Old Jun 1, 2005 | 10:04 AM
smokedmustang's Avatar
mine was cracked, due to not being lubed properly. and I leaked fluid, but got it to the shop before it went kaboom. its easy to pinch this "ring" and cause problems down the road. the Mitshu dealer told me this is usually why people have TC probs AFTER a clutch change! Good luck!
Old Jun 1, 2005 | 10:09 AM
4ringturncoat's Avatar
Mine was working great for a few months and then after a few hard launches she started leaking. Anybody else have this problem?
Old Jun 1, 2005 | 10:11 AM
Curt@MrLed's Avatar
Former Vendor
if its not leaking leave it alone..
Old Jun 1, 2005 | 11:26 AM
bolsen's Avatar
there's no fluid in it yet lol
Old Jun 1, 2005 | 12:35 PM
marksae's Avatar
Are you talking about o-ring 19? The big one?
Old Jun 1, 2005 | 12:44 PM
instigator's Avatar
Yes.
It isn't too bad to replace. Just pul the downpipe and the pasenger side axle and it should be able to come out after removing the 6 bolts holding the TC on. Then swing it to the side and replace the ring. Just lube it before putting it back in.
Old Jun 1, 2005 | 12:54 PM
superz's Avatar
What I have seen most is the small o-ring missing or fallen off. The big one I have never seen broken.
Old Jun 2, 2005 | 10:53 AM
bolsen's Avatar
what is the small one? oil passage?
I'm goina take it off again and look at it. Might as well since it's out of the car anyway.
Old Jun 2, 2005 | 11:17 AM
marksae's Avatar
When I installed my quaife front LSD, I wondered what the hell that small o-ring was for. There's another o-ring of the same size downstream on the t-case cover. There's no passage on the cover, so maybe there's an oil passage on the housing somewhere. I forgot to look for one when I had mine apart.
Old Jun 2, 2005 | 11:19 AM
DCSilvrEvo's Avatar
Originally Posted by instigator
Yes.
Not exactly that easy there is a shaft that you have to pull out. It can be a REAL B!TCH!!!
