Engine tapping/nuetral rev
Old Jun 1, 2005 | 11:06 PM
mobounce's Avatar
Ok, I come home from work tonight, and when I rev the car in nuetral, I hear taps randomly. I dont know if its my engine or underneath the car... (i think its the engine)...it dosent do it at all when idle, and I cant hear when I'm under load (because of the exhaust and spool of the turbo). I never heard this before. I heard it well since i park between 2 cars under a carport.
I'm thinking lifters? I hope its not a rod!! My car is acting normal though, I dont notice any difference in strength.... please dont scare me, but what can it be?
Old Jun 1, 2005 | 11:52 PM
TrikeDOutEvo8's Avatar
same thing happened to me 3 months ago...i heard it slightly and then a few months later...BOOM....blew the bottom end...it starts around 3k rpm's and its quiet...you wont hear it with your stock setup..becuae i didnt hear it when i took it to the dealer the first time....but it turned out that i snapped the rod later on down the line...so be careful and take it to the dealer IMEDIATELY....i can bet you that its a rod...but i really hope its not...if you have to pay for it, its gonna be almost 10g's to fix!
Old Jun 1, 2005 | 11:57 PM
mobounce's Avatar
what??? are you kidding?? 10gs????????????????????????? And I can't go to the dealership!! I'm heavily modded. Looks like Ima have to build the bottem end. Anymore input from anybody?? I only started hearing it tonight, and only in nuetral when i rev...not when i idle. Take a look at my mods. I'm just barely making 400awhp....
Old Jun 2, 2005 | 12:02 AM
mobounce's Avatar
bump...help!
Old Jun 2, 2005 | 12:29 AM
mobounce's Avatar
Bump
Old Jun 2, 2005 | 05:10 AM
EvoTech's Avatar
I starting hearing a smiliar noice last week. It sounded to me like a deep engine noise which is always a bad thing. It could be heard best with my mear inside the left front wheel well. Anyway I had someone depress the clutch while I was listening and guess what?? No more noice. What a relief that was. It must something with the throwout bearing or something. Give it a try and see if it goes away. Good luck.
Old Jun 2, 2005 | 05:18 AM
HiHeatEVO's Avatar
it may be the lifters. i changed out some cams once and the car clicked for a minute or two like loose change was inside the valve cover. It stopped after about 5 minutes; i guess they just had to refill.
10k to fix a bottom end???? holy crap. You can get a fully built, stroked, and balanced block installed for that much, and a new valve train and head probably. WOW.
Old Jun 2, 2005 | 06:00 AM
PVD04's Avatar
Open your hood and rev the engine while leaning over it. You will likely be able to hear if it is coming from the lifters. I can hear a slight tick when I rev my engine in neutral, but I don't think I've ever heard it with the hood closed.
-Paul
Old Jun 2, 2005 | 08:14 AM
mobounce's Avatar
Is there a true way to diagnose this problem? I'm getting real worried.
Old Jun 2, 2005 | 08:19 AM
scottatyamaha's Avatar
sounds to me like a lifter tick from the cam install.
Old Jun 2, 2005 | 08:23 AM
EvoTech's Avatar
try to engage the clutch and see what happens.
Old Jun 2, 2005 | 08:32 AM
mobounce's Avatar
I have had my cams in for over a year...and NEVER heard this before...and like i said, I only here it when i rev in NUETRAL.
mobounce's Avatar
going to try this now...
deadstockkpomp
Jul 8, 2012 03:06 PM
jj_008
10
Jul 11, 2010 10:46 AM
def1
Sep 3, 2008 06:56 PM
Malik_EvoIX
11
Aug 19, 2008 10:58 AM
TrinaBabe
Feb 28, 2005 04:18 PM
