boost problems.. =(
Old Jun 7, 2005 | 08:09 PM
ultraflip's Avatar
boost problems.. =(
o.k. everyone....
problem: my car holds boost to 1.5... every now and then while shifting it may spike to 1.8... but in 2nd 3rd and 4th gear... it tapers down after 5krpm to 1.1-1.2 bar...
the mods:
arc intake
helix dp
perrin tp
hks hi-power canister
greddy type rs bov
greddy upper ic
fuel pump
denso 720 injectors
hks 264/272 cams
dejon tool for boost controller
safc for tuning
now... what should i look at//check//tighten etc. to help my boost woes... the BOV has been set correctly... that is not the problem...
Old Jun 7, 2005 | 08:14 PM
ultraflip's Avatar
3 second bump
Old Jun 7, 2005 | 08:23 PM
Iamkar33m's Avatar
whoops, read closer. Is the dejontool boost controller manual or electronic?
Old Jun 7, 2005 | 08:25 PM
bigjhoney's Avatar
Originally Posted by Iamkar33m
what kinda boost controller are u using? MBC? EBC? None?
dejon tool for boost controller ( its manual)
Old Jun 7, 2005 | 08:27 PM
bigjhoney's Avatar
Has it been more humid than usual when this happens. I notice when its real humid my car tapers about 2/3 psi from where it spikes, but on nice cool nights I hold my boost to redline.
ultraflip's Avatar
no... not humid... regular weather... nothing out of the ordinary
Old Jun 7, 2005 | 08:28 PM
Iamkar33m's Avatar
We live in so. cali... humidity is like almost non-existant. Just arrid dry heat
Old Jun 7, 2005 | 08:30 PM
bigjhoney's Avatar
Well....time to build a boost leak test
http://vfaq.com/mods/ICtester.html
ultraflip's Avatar
i'm losing about 4psi through my curve
Old Jun 7, 2005 | 08:33 PM
bigjhoney's Avatar
Yea sounds like a leak..
Old Jun 7, 2005 | 08:52 PM
ultraflip's Avatar
bah! where can i get a A 4 inch long piece of 2.5" O.D. (outside diameter) hose. ... i have everything else..
Old Jun 7, 2005 | 08:54 PM
AD_LIB's Avatar
flip where did you tap the line for your dejontool? I hit mine up by the intake manifold and it seemed to hold boost much steadier.
Old Jun 7, 2005 | 09:14 PM
bigjhoney's Avatar
Did it start doing this after you installed something, or did it start out of no where.
Old Jun 7, 2005 | 09:23 PM
Warrtalon's Avatar
Home depot in the plumbing section. They have small couplers that should do the trick, and some even have clamps on the end already.
Old Jun 7, 2005 | 10:04 PM
ultraflip's Avatar
tapped where towards the front of the valve cover... closer to where the BOV is
