Ngk BPR7EIX question
Old Jun 14, 2005 | 09:13 AM
bigjhoney's Avatar
They come pregapped...but they what? Ive heard that you can ruin them by gapping them, but how are you supposed to gap them then? Are they the same gap as non-iridium plugs, Should I go with these iridium plugs, or just the regular 7es. thanks
Old Jun 14, 2005 | 09:22 AM
domestickilla's Avatar
the BPR7EIX iridium are already gap... and i heard you dont need to gap them. anything different please post... i have them and waiting to put them in....
Old Jun 14, 2005 | 09:31 AM
bigjhoney's Avatar
yea i just wanted to know what gap they are, because ive been toying with gaps before and my car runs best at a certain one.
Old Jun 14, 2005 | 09:36 AM
GTVEVO's Avatar
If you are running alot of hp in the upper rpm range you will need to regap them to about .025-.026 on the stock ignition. You can regap them without issue but on the stock turbo you probably won't have a problem with the gap the come with.
Old Jun 14, 2005 | 09:45 AM
Soon2BEVO's Avatar
I put in BRP7EIX's last week, they were gapped at .026.
My manual says plugs should be between .024-.027, so I didnt have to touch them!
Old Jun 14, 2005 | 09:47 AM
kool thanks for the info....
Old Jun 14, 2005 | 10:14 AM
GTVEVO's Avatar
Cool good thing you checked. Mine were gapped at .028 when I recieved, very weird that there was a difference.
Old Jun 14, 2005 | 10:19 AM
bigjhoney's Avatar
Any tips on gapping iridium plugs and not messing them up?
Old Jun 14, 2005 | 10:23 AM
3deep's Avatar
just use needle nose pliers and be careful.if you gap them to much lightly tap them on hard surface to reduce gap,easy.
Old Jun 14, 2005 | 10:37 AM
skiracer's Avatar
read this: http://densoiridium.com/installationguide.php
Old Jun 14, 2005 | 10:49 AM
GTVEVO's Avatar
This being the reason for most issues like discribed in the link above.
Note: Never use a round gapping tool to check the gap or to increase or decrease the gap setting.
Old Jun 14, 2005 | 10:52 AM
bigjhoney's Avatar
Thanks, and yep only use the gapper that looks like a swiss army knife, my friend used a round one, and when we checked them with the swiss army looking gapper they were all off by alot.
Old Jun 14, 2005 | 10:55 AM
GOKOU's Avatar
Pictures would help cause I've been using the round circle I'm assuming it's different then a feeler gauge
Old Jun 14, 2005 | 10:58 AM
Nez136's Avatar
what if i used the gap tool instead of a pliers?
Old Jun 14, 2005 | 11:51 AM
EVO3675's Avatar
Exclamation easy gapping on the first shot
Take your plug and a feeler guage (what ever you are wanting to set the plug to) put the plug in a vise in like you are going to crush it long ways make sure to put something on each side of the vice so its not metal to metal with the plug like wood or plastic its got to be flat though tighten te vice just enough to hod th plug in place now once its in put the feeler in between the electrode and ground electrode and tighten the vice till you feel a light drag on the feeler guage when you move it back and fourth this is mu ch easier than using a gapping tool or pliers
