Ngk BPR7EIX question
Old Jun 14, 2005 | 05:04 PM
bigjhoney's Avatar
Originally Posted by GTVEVO
Cool good thing you checked. Mine were gapped at .028 when I recieved, very weird that there was a difference.
Mine were also at .028, and I left them at that.
Old Jun 14, 2005 | 05:18 PM
[Cyanide]'s Avatar
I've been gapping my NGK Copper plug (1 step colder than stock) with the round gapping tool at .028 with no problems.
Old Jun 14, 2005 | 10:29 PM
yellowman's Avatar
Do Not Regap Iridium Plugs....i Repeat Do Not Regap Them!!!!!
After Regapping Mine, Two Of Them Broke Off In The Motor!
Old Jun 15, 2005 | 08:46 AM
3deep's Avatar
either you soften the metal too much by gapping to many times or you have major detonation going on.
Old Jul 12, 2005 | 10:34 PM
plokivos's Avatar
you don't gap iridium plugs.
Old Jul 12, 2005 | 11:28 PM
timzcat's Avatar
Originally Posted by EVO3675
Take your plug and a feeler guage (what ever you are wanting to set the plug to) put the plug in a vise in like you are going to crush it long ways make sure to put something on each side of the vice so its not metal to metal with the plug like wood or plastic its got to be flat though tighten te vice just enough to hod th plug in place now once its in put the feeler in between the electrode and ground electrode and tighten the vice till you feel a light drag on the feeler guage when you move it back and fourth this is mu ch easier than using a gapping tool or pliers
Do not do this!!
You will damage the porcelein and render the plug useless. Spark Plugs are very sensitive. If you ever drop one you might as well pitch it in the trash. This goes for buying them at the store, if they drop it refuse it. I have seen literally 100 plugs dropped that had to be replaced after a couple of miles.
round gappers are designed for used plugs not new, but never iridium plugs.
I wouldn't gap an iridium unless it is way off from the manufacturer.
Old Feb 13, 2011 | 06:12 AM
evo585's Avatar
Here is some info from NGK since a lot of the info posted is misleading and incorrect.
http://www.ngksparkplugs.com/tech_su...de=nml#gapping
3. Gapping
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability
in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think.
Old Feb 13, 2011 | 06:58 AM
han's Avatar
han
a 6 years old thread lol, you never gap iridium plug
Old Feb 13, 2011 | 08:30 AM
TommiM's Avatar
snap on sells two different types of gappers safe for platinum and iridium plugs. One is a tool similar to like pliers that presses the ground tip out. One common issue with these is they can snap the tip off easily. The other type is similar to like a mini ruler that has a square/rectangular hole cut out that you use to wedge the tip end on. It adjusts the gap without ever coming near the iridium tip. I use that one all the time on my iridium plugs, and any plugs that I do for customer cars. Any plug can have its gap adjusted except those Bosch +2, +4s with the multiple tips. Those Boschs dont want them to be adjusted, but we dont run them on the evos so doesnt matter. I tried finding some pics of these tools, but snap ons website is horrible, sorry.
Old Feb 13, 2011 | 03:24 PM
evo8426's Avatar
wrong, you still have to gap the plug
Deanooo
Aug 25, 2016 05:17 AM
5LEEPERISAH23I
Apr 23, 2014 02:45 AM
ilikeboost
Mar 21, 2011 06:58 AM
catman78
Nov 21, 2010 01:10 PM
oldevodude
E85 / Ethanol
34
Apr 14, 2010 07:46 AM
