Changed spark plugs, now have boost problems
Old Aug 24, 2016 | 02:13 AM
Deanooo's Avatar
Hi,
I have recently changed my spark plugs from NGK PGR7A'S to BPR8EIX's. The car is running fine but the only problem I am having now is that I am barely hitting boost. I did not gap the new plugs as i read on here you shouldn't gap iridium plugs. My car is running 27psi with supporting mods on stock turbo. Should I just get rid of my BPR8's and get some BPR7's?
Thanks
Old Aug 24, 2016 | 06:13 AM
06RedRalli's Avatar
Plugs should be good. But go back and gap them using a feeler gauge.
Old Aug 24, 2016 | 06:32 AM
edsct9a's Avatar
Gap the plugs. I did that not to long ago and on wot it would misfire/breakup on he higher rpms.
Old Aug 24, 2016 | 03:11 PM
Bhsj13's Avatar
you need to gap the plugs, the gap will be big. i bet it will read .032 or so which will cause park blowout. gap it down to .022 imo and it should be ok.
Old Aug 25, 2016 | 04:31 AM
Deanooo's Avatar
I have put the old plugs back in just to see if the boost would be back to how it was before, but still having boost issues?
Old Aug 25, 2016 | 05:17 AM
wolgy88's Avatar
Sounds like a coincidence that you noticed this issue with the plug change. If switching back to the original plugs didn't correct the issue then it's clearly something else. I would check for boost leaks. Check couplers/clamps, throttle body, hoses, nipples, etc.
jaimeptwo
Oct 8, 2014 03:09 PM
turboman8
16
Feb 18, 2010 05:49 PM
4WS Tuning
28
Feb 5, 2007 06:07 PM
deegaw11
12
Sep 20, 2006 08:56 PM
Bosshog
32
Sep 5, 2006 11:54 PM
