changed spark plugs, made puttering sound
i just put in new oem plugs. i started it up and every 3ish seconds it would make a popping sound...
is that normal for a little bit? i only had it running for 10 seconds..
first time changing the plugs
thanks!
thanks!
o sorry, well it means either your spark plugs are not gapped correctly, but you said you got oem ones so, they should correct. Also when I said it is missing, I meant it is mis-firing during idle. Try reving it up some and see if it gets worse!
gapping is to spec... havent changed them... just measured them straight out of the box..
idk about revving it up... that doesn't sound like a great idea...
whats worst case senerio? i need new plugs again?
or can i blow something up?
