just changed spark plugs, is this normal?
Old Sep 19, 2006 | 03:51 PM
deegaw11's Avatar
i just changed my spark plugs to bpr7es and i gapped them at around .028. my car is mostly stock with a tbe,drop in and that's it. after i finished installing them i turned the car on and the rpm raised all the way to like 2500 and dropped back down to 300 then it went back up and idled around 900. the idle seems smoother than b4. also when im driving now the exhaust is louder but it rides smooth. is that suppose to be normal? hmm what are signs of misfire? first time i changed plugs on a evo so im sorta clueless.
Old Sep 19, 2006 | 03:56 PM
vboy425's Avatar
well, it's normal to me. but double check makesure the sparkplugs are tighten correctly. Not too tight and not too loose. You should of gap them .022mm-.024mm. Also makesure the connectors are clean of debris and snap all the way in. Makesure your spark plugs wire are seating properly.
Old Sep 19, 2006 | 04:04 PM
gsrboi80's Avatar
Normal dont worry. Like vboy said just go back over everything if you worried. torque them to 18ftlbs if you can
Old Sep 19, 2006 | 04:28 PM
deegaw11's Avatar
i dont have a torque wrench and when i took the old plugs out 2 of them came out really easy and 1 of them was really tight. i just tightened them until it was tight but not too tight.
Old Sep 19, 2006 | 04:37 PM
stingerbtry's Avatar
Are the plugs/gap the same for the IX? I remember going to a parts store looking for them and they said they wouldn't work in the 2006 and that there were totally different plugs for the mivec engine. I've searched around but not found much conclusive about the IX as far as plugs are concerned and Mitsu wants a fortune for them.
Old Sep 19, 2006 | 04:42 PM
deegaw11's Avatar
im clueless but what are signs of misfiring and what not.
Old Sep 19, 2006 | 09:40 PM
red evo8's Avatar
i'd say dont worry about it mine seems to do this w/e i disconnect the battery
Old Sep 19, 2006 | 09:46 PM
red evo8's Avatar
Old Sep 19, 2006 | 09:51 PM
tripperfx3's Avatar
If your worried about misfiring. When the car is cold crank it up and put your hand near the exhaust. You should feel a off beat exhaust pulse. If it happens you'll know it. After it warms up test it again and feel for the same thing. You should also be able to hear it. Its pretty noticable off beat exhaust pulse. It can also happen under load while driving, but that you'll just have to listen for. Also i believe if you have a misfire in the Evos it will eventually throw a CEL because misfires produce more emissions, so they want the engine to be as clean as possible. If anyone else can clear that up it be appriacted.
Old Sep 20, 2006 | 01:16 PM
tripperfx3's Avatar
Also from what ive seen lots of people have had good luck with the BPR7Es, but its always recommended to stick with OEM if at all possible. Im an auto tech student and all of my teachers have tried the fancy platinum tipped plugs and aftermarket plugs in general and had problems. I personally have also had great luck with the NGKs in my old 240, but im gonna try to stick with OEM ones if i can afford it when it comes time.
Old Sep 20, 2006 | 02:12 PM
gsrboi80's Avatar
Do not put platinum plugs in a turbocharged car. Youll regret it. Use I use the Copper BPR7ES gapped to .026 no missfire codes. You can use the irridiums if you want but in my experience the coppers make my car run way smoother
Old Sep 20, 2006 | 07:56 PM
deegaw11's Avatar
damn i have no idea if im getting any misfire but my car is throwing a code. but it threw a code after i put the UR test pipe on so i dont think it has to do with the spark plugs..i've been driving with the engine light on for about a week now. does it affect me in anyway or it doesnt?
Old Sep 20, 2006 | 08:56 PM
DanJ's Avatar
Just to make sure. Don't overtighten the plugs. Finger tighten with just the socket itself, then do 1/2 a turn with the wrench.
sXericerider
Lancer Troubleshooting
Nov 14, 2009 02:12 PM
Kid Lancer 7
May 25, 2006 06:58 PM
Silver05Bullet
Oct 19, 2005 03:12 PM
fuzzychi
14
Jul 12, 2005 11:07 PM
hawkmoon
13
Jan 26, 2004 11:36 PM
