Lovefab Manifold :P
Old Jun 14, 2005 | 04:59 PM
KasEVO8's Avatar
hummm looks very interesting, Lovfab makes pretty good manifold but this one looks interesting.
Old Jun 14, 2005 | 06:45 PM
94AWDcoupe's Avatar
Thats an extremely well designed header. While having an elbow right at the entrance of the turbo is not a good idea, there is plenty of room for the gasses to make there turn on this header. The wastegate entrance is as good as it gets. Good luck with the setup.
Old Jun 15, 2005 | 12:54 AM
trinydex's Avatar
that is one hard 90 degree bend....
Old Jun 15, 2005 | 12:58 AM
EVO8HKS's Avatar
say good bye to the radiator hose.
Old Jun 15, 2005 | 05:10 AM
scorke's Avatar
Should this thread be retitled, "Blind Kid Finds Stainless and Welder-Pics Inside" ????
Scorke
Old Jun 15, 2005 | 10:58 AM
evo81's Avatar
looks good.i would make a custom radiator pipe now also.looks like it'll burn the stock one up
Old Jun 15, 2005 | 12:50 PM
ISPracing's Avatar
This manifold is amazing. We have designed these manifolds in conjunction with Cody, awesome work. They will be included with our turbo kits and as you can see has already been on our race EVO.
Old Jun 15, 2005 | 02:09 PM
jordo's Avatar
Originally Posted by Evol_VIII
Boost creep big time with the waste gate being after the inlet flange to the turbine. Also the hard 90 degree turn into the turbine housing can't be good for flow.
that is the oposite of what it would do. I would not boost creep, due to the exhaust gas going straight into the wastegate.
Have you guys ever seen this manifold design?
this is one of the most well designed manifolds.
Old Jun 15, 2005 | 02:12 PM
ISPracing's Avatar
I second that!
Old Jun 15, 2005 | 04:07 PM
SeanJhn9's Avatar
wow, that is looking good....how much does a minfold like that run
Old Jun 15, 2005 | 06:34 PM
plokivos's Avatar
before I assume anything, I would like to see some numbers with those things.
the looks could be deceiving when it comes to airflow and bends.
sometime a bend could help digress the air faster than straight ones.
ot: yeh, sae's fun. Has an opportunity to do some aerodynamic outer skin design for brown university sae team.
It was fun working with the pink foam. lol
Mikey@Spec-Ops
Evo X Dyno Results
123
Mar 26, 2012 10:02 AM
oriley9959
Aug 7, 2011 01:30 AM
edog145
Aug 18, 2010 07:35 PM
djevoawhp
30
Jul 19, 2010 07:49 AM
EidolaDream
28
Jul 15, 2005 06:36 PM
