Pruven fuel rail adapter question
Old Jun 17, 2005 | 05:38 PM
sandm's Avatar
gettin ready to install a greddy fuel pressure gauge.. purchased a pruven fuel rail adapter used. didn't come with instructions. looking at it, appears that it can be installed on either end of the fuel rail. if I install on the inlet side, the pruven logo will be backwards facing the rear of the engine bay where you will not see the logo. I am "assuming" that this needs to be installed at the end of the fuel rail where the return line is to the tank so you can see and read the pruven logo (for advertising I am sure).... not sure that it makes a diff, except that now you are monitoring after the injectors in the flowpath, not the higher number prior to injectors...
thoughts??
thanks
Old Jun 17, 2005 | 05:45 PM
lqdchkn's Avatar
need pic or link to pic
Old Jun 17, 2005 | 09:06 PM
sandm's Avatar
bumpity bump....
