Clutch and Engine Questions
Old Jun 19, 2005 | 09:43 AM
goathead's Avatar
Question Clutch and Engine Questions
Took my 05 Evo VIII to an 1/8 mile event last night and need some help. First launch was pretty hard, spun all four tires a good bit, after the run I noticed a really
bad burnt clutch smell which I can still smell a little today. Also, on the first run I
revved the engine to around 8500 rpm between first and second and then to 8000
from second to third without hitting the rev limiter. I went way easier on the clutch
and never let it rev over 7000 for the rest of the night. Is the clutch smell common?
And what is the stock rev limit? Any help would be greatly appreciated from this
newcomer.
Thanks,
The Ghead
Old Jun 19, 2005 | 09:57 AM
platinumspecv's Avatar
8500? dude your evo bone stock?
Old Jun 19, 2005 | 09:58 AM
I dont know if you notice it... but the "redline" is the rev limit
Old Jun 19, 2005 | 09:59 AM
vrrrm...psss's Avatar
clutch smell is common when launching hard.......dont do it very often unless you want to change that bad boy out very quickly
Old Jun 19, 2005 | 12:06 PM
goathead's Avatar
Evo is bone stock so far.
Old Jun 19, 2005 | 12:14 PM
an0ther's Avatar
stock limiter is either 7400 or 7600. Not sure your goin to 8500. I have a dynoflash and mine was raised to 7800.
Old Jun 19, 2005 | 12:15 PM
Bar's Avatar
Bar
umm 8500 revvs?
Old Jun 19, 2005 | 12:28 PM
I dont believe you have an EVO. I think ur makin it up. You would have hit the rev limiter on a stock evo. No way in hell is it going to let you rev till 8500rpm. so i call BS!!!
Old Jun 19, 2005 | 12:34 PM
WildRice's Avatar
8500 will float the valves. Can you say "CRASH"! Your tach is messed up. If you over slip the clutch you melt then burn the disk and yes it smells.
Old Jun 19, 2005 | 05:31 PM
Rcebowl's Avatar
ummm i havent hit 8500 .. but on my stock 03 evo 8 i can hit 8200 ... i normally dont because you can tell the power drops alot that high...
Old Jun 19, 2005 | 05:33 PM
plokivos's Avatar
clutch and engine. like sex and candy. lol
Old Jun 19, 2005 | 05:36 PM
plokivos's Avatar
by the way, i thought people launching at redline and returning the car to the dealership with 2000 miles complaining about how it's fried was a myth, but I guess that's true... There are "people" like that.
Old Jun 19, 2005 | 11:09 PM
white05evoVIII's Avatar
yeah i don't drive miss daisy in my car and i haven't broken anything yet(knock on wood)
Old Jun 20, 2005 | 05:19 AM
goathead's Avatar
Not making anything up, tach went well over 8000 rpm twice, and I'm almost positive it's an EVO, I think.
The Ghead
Old Jun 20, 2005 | 05:34 AM
Compjoc's Avatar
did u buy ur evo new from the dealership or used from someone?
