Electronic boost controller detailed explanation
Old Jun 19, 2005 | 10:07 AM
sayanara's Avatar
I hope this isn't a stupid question. I'm trying to find out how the ebc on the market work. The Hks uses a stepper motor while the greddy and blitz use a solenoid? Can someone give me a detailed explanation of how these work and how they can be compatible with a standalone unit. I'm not looking for the which is the best answer just trying to learn how they work.
Thanks.
Old Jun 24, 2005 | 12:44 PM
sayanara's Avatar
No one?
Old Aug 22, 2005 | 03:07 PM
ninjadoc's Avatar
I know nothing about the HKS. The blitz, Greddy, and Apexi use a solonoid. They will control boost separately from the stand- alone ECU. If you want the stand alone ECU to control boost you take off the boost controller and use a GM solonoid or the solonoid of your choice and following the directions of your ECU you wire it, set - up the ECU, and modify the MAPS accordingly. Each is differant...the AEM has tables to set up, the Autronic uses the stock solonoid, and the XEDE uses the stock solonoid.
Gary
Thanks.
