camshafts and daily driving
Old Jun 19, 2005 | 11:03 AM
SMrider102's Avatar
I use my evo as my daily driver and have a set of 264 camshafts. I really want to install them but I am so afraid of something happening....what are you guys' opinion on camshafts wiht a daily driver? could they cause a lot of harm, I plan on doing the dynoflash for them too if that helps any... this topic has probably been beaten to death but I couldnt really find a clear thread on it
Old Jun 19, 2005 | 11:25 AM
PHILLY EVO's Avatar
I have them and are great on the stock turbo no stall or anything but you will have to get your ecu flashed also go with 660 inject.
Old Jun 19, 2005 | 11:29 AM
Smogrunner's Avatar
You do not need bigger injectors at this point in the modification process. The 264 cams will give you no problems and will idle almost like stock. Go for it.
Old Jun 19, 2005 | 11:30 AM
quiksilverevo26's Avatar
you should have no problems, especially with the 264's. Let just say it will idle like stock but the car will have a lot more ummmmmmmffffffffffffffffff!!!!
Old Jun 19, 2005 | 11:47 AM
SMrider102's Avatar
so would i need the injectors? so far i have a turboback exhaust with cat delete, hks rs intake, mbc, walbro fuel pump and a flash...i also plan on getting intercooler piping soon.
this set of camshafts are used also, should I be worried about that, they were in another evo for about 3/4 thousand miles
Old Jun 19, 2005 | 11:52 AM
Novtec1's Avatar
Veteran: Army
i've got 272's had em in for about 6 months now, im used to the idle and does not affect my daily driving at all.
Old Jun 19, 2005 | 03:49 PM
bigmac's Avatar
No, you won't need injectors. I have HKS 264s with Vishnu cam gears (which weren't really necessary either) and the Walbro 255 and BR exhaust. No idle problems at all, and no starvation problems with stock injectors--even had it dyno tuned a little bit rich to be safe (I have the xede). You will have no problems and you will feel a good difference in torque.
Old Jun 19, 2005 | 03:56 PM
jesterEVO's Avatar
i am installing 272's soon for daily driving....you should have nothing to worry about...264's you wont even notice
Old Jun 19, 2005 | 04:01 PM
SMrider102's Avatar
sounds good...but what about the fact that they are used? that shouldnt really be a problem right?
Old Jun 19, 2005 | 04:18 PM
jesterEVO's Avatar
just over look them for physical scars....you should be fine
Old Jun 19, 2005 | 05:02 PM
plokivos's Avatar
so, any problem with 272/272?
Old Jun 19, 2005 | 05:12 PM
DCSilvrEvo's Avatar
Thats what I wanna know PLOKVOS.
Im getting GSC 272 w/o gears i hope idle is not bad.
blueo4's Avatar
I have the BC combo, AMS 680 +++ and daily driving is a breeze! The only problem I have is road space! The car is like "Indecka", you just want to step on it all the time!
I would get 92oct or better! god dam 91 sucks $ car idles rough on it!
Old Jun 19, 2005 | 05:16 PM
tke_413's Avatar
264's will give you a LITTLE bit of lop in your idle...but very little. I'm running them in my daily driver with stock injectors - no problems.
Old Jun 19, 2005 | 05:38 PM
plokivos's Avatar
i know 272/272 idles like a v8 on crack, but how is that on daily driving?
