Tilton clutches
Old Jun 22, 2005 | 11:54 AM
Sean@Iveytune's Avatar
Originally Posted by Geo@EvoStore
He does have the carbon/carbon. It is very noisy. Works perfect though and shifts awesome.
However his is basically not the Tilton full setup as that won't be released for about 1.5 months. We already have a few on order Price will be $3795 for the carbon/carbon and it comes with hydraulic release bearing. As said above though there will be a few versions ranging from $1699 to the carbon version. Tilton will have a official press release about it later this week.
I have the carbon to Carbon TILTON , there is no noise. The noise you would normally hear like in the Exedy metallic or quartermaster or any other clutch with metal floaters and pressure ring is not there in a tilton carbon clutch.
The noise you hear at idle in a metallic clutch (exedy, tilton, ap, quartermaster, clutchmasters twin ) is the drive lugs contacting the floaters and the pressure ring. It is normal and a characteristic of this type of clutch.
During coast down the tilton makes no more noise than the exedy twin.
Tilton is slao the most versatile, 2 pressure plate ratios........6 diaghram spring options and perhaps the best record of any manufacturer in competitive motorsports.
http://www.tiltonracing.com/content.php?page=2k4
Touch that.
Sean
Old Jun 22, 2005 | 12:00 PM
nickracer9's Avatar
is it going to be push or pull type?
Old Jun 22, 2005 | 03:30 PM
03EVO583's Avatar
Tilton will be a push-type, using a concentric hydraulic release bearing that eliminates the external slave cylinder and related linkage. The hydrtaulic release bearing assembly will mount inside the bellhousing/transmission. The kit will a include steel braided clutch line to connect to the stock master cylinder.
Old Jun 22, 2005 | 08:50 PM
Zeus's Avatar
Originally Posted by TalonRcR
If your a puss you don't need a tilton. These clutches are in the most powerful cars in the world, Anyware from F1 to Drag racing.
Chris
No SHlT Dick Tracy... there was a bit of cynicism in there.
Old Jun 23, 2005 | 06:49 AM
nubby's Avatar
Registered User
More info from Tilton:
We originally developed the hybrid clutch for Performance Nissan who we
worked with to develop clutch package for 350Z applications. The feedback
they provided was that the hybrid clutch was good for street use, engaging
very smooth when compared to the full cerametallic clutch. The carbon
clutches also engagement very smoothly, but the price is about double.
We are hoping to start shipping assemblies by July 29th. The assemblies
will include a 7.25" 2-plate clutch, billet steel flywheel and a hydraulic
release bearing assembly that replaces the stock slave cylinder and related
linkage. They will be one of our most "bolt-in" clutch package offered,
designed to work with the stock master cylinder (other application require
changing the master cylinder to a larger bore size). We have engineered the
clutch-flywheel-assembly to provide lower weight/inertia for more wheel
horsepower, but not too low of weight/inertia that would negatively effect
drivability.
Suggested Retail Pricing:
Cerametallic package: $1795
Hybrid package: $1825
Carbon package: $3995
We are finalizing a flyer that will show these clutch packages. We hope to
have further information on our website by Friday. I have attached a
spreadsheet that lists all our sport compact/import offerings, including
prices, weights and torque capacities.
Weights from the .xls (includes HRB):
Carbon-Carbon: 16.2 lbs
Cerametallic: 19.1 lbs
Hybrid: 19.1 lbs
Old Jun 29, 2005 | 03:35 PM
Geo@EvoStore's Avatar
Tilton Evo & WRX Press Release
Old Aug 28, 2005 | 12:09 PM
badlooser's Avatar
Tilton
Old Aug 28, 2005 | 12:35 PM
broeli's Avatar
Wow. The entire clutch assembly including flywheel is only 19.1lbs?! I think an Exedy twin disc is 34.xx and a single disc ACT is 32lbs.
Old Sep 2, 2005 | 01:02 PM
Now in stock
http://store.evostore.com/tiraclforevo.html
Old Sep 16, 2005 | 01:53 AM
BADEVO's Avatar
Old thread but I figured I'd bring it up. Can someone who has installed one of these provide a little more info on this >> " hydraulic release bearing assembly that replaces the stock slave cylinder and related linkage. "
Old Sep 16, 2005 | 06:57 AM
Zeus's Avatar
For $1700 it makes it real tempting compared to the Exedy twins...
Old Sep 16, 2005 | 07:05 AM
Shaker Motorsports's Avatar
An Exedy twin can be purchased for much less than $1700.00 and performs very well.
Even the Quarter Master clutches we sell are $1700 with the hydraulic throwout bearing worth $400.00. Both come with a lightened flywheel.
The real question is how many people are ready to dish out that much money for a clutch? We have sold several of the Exedy Twins but not like they are hot cakes and our price is very low.
For the majority this clutch overkill. For power-making weekend warriors and most racers and Exedy or QM is the choice, only the elite enthusiast/racer will be willing to spend this much on a clutch. I wish they all were like the latter.
Old Sep 16, 2005 | 07:08 AM
BADEVO's Avatar
Question is , IS your opinion based on the fact that you sell Exedy and QM ????
I have been quoted over 1700 on an Exedy Twin. I'd be interested in your price as you stated its MUCH LESS. PM me if you will
Old Sep 16, 2005 | 07:23 AM
nubby's Avatar
Registered User
I'm not quite sure why someone would choose a QM over a Tilton if the price is the same.
It's expensive to do a clutch job on an Evo, so why not invest some money in the clutch itself, rather than on the labor changing them?
Old Sep 16, 2005 | 07:34 AM
Zeus's Avatar
I've not heard of anyone running the Tilton yet... It will be interesting to see if there are any issues what so ever. It's not like they have a name or anything
I've also only heard of domestics running the quartermaster stuff... which in and of itself is just as meaningless to me...
