JDM MR BOV- Higest Boost obtained?
What is the highest boost spike or peak that you are able to obtain with the JDM MR BOV? I have one and a friend of mine has one. When running race gas and turning up the boost, we can obtain more than a 27 psi spike even with no wastegate line. Another guy has a similiar setup, but a Greddy Type S with both springs in it, he can spike to 29.6 psi on his. His hold boost slightly higher than our cars do to.
Just curious as too if anyone has been able to run more than 27 psi peak with a JDM MR BOV?
If this is really a problem, then I can see how the BOV could actually make torque and hp, when running the turbo at full tilt.
Brian
Brian
If you can disassemble it, just remember you could always shim it
Oh one other thing, BOV don't make power, they only hold the power the motor makes.
In other words, if I change nothing else on my car on the dyno, BUT the BOV. I make another pull and my boost is higher, and I make additional torque and/or HP, then the BOV was responsible for allowing the engine to make the additional torque and/or HP.
I agree if you are running lower boost, that the weaker BOV is able to hold, and you install another stronger BOV that doesnt leak either, you wont make HP.
However, I think, back to your original thought about the shims. I dont think you can take the cap off the JDM MR Bov. You would need to be able to remove the cap to access the spring. You can take the adapter off though. I wonder if you could take the adapter off and crush it similiar to the 1g Valves.
Brian
Has anyone else had this problem with the JDM MR BOV though? I am not 100% sure it is the BOV, but I am highly suspicous that it is the culprit. If others have had similiar experiences with this BOV, then that will solidify my theory, at least in my mind..
Brian
Brian
Well, the DV doesn't directly see WOT air flow, so I don't see how it's the bottleneck. The only effect it has on air flow is at vent...
But on this note, I'll agree to disagree that a DV makes any power at all. IMO it can only hold/lose the power your motor currently makes.
You probably aren't getting many responses on the limits of the MR DV, because those of us that get it aren't really trying to push it to its limits. I got mine just to be better than the POS plastic stock BOV, but not to attract any attention via bling or noise. Mine is nice and quiet, and holds boost wonderfully en route to 12.2 and 12.3s runs @ 22-23psi.
arpad
179
Feb 9, 2020 03:51 AM
ChipperEvo
Sep 29, 2012 08:57 PM
TTP Engineering
26
Apr 2, 2010 09:31 AM
