Samco rad hose heat tolerance?
Old Jun 24, 2005 | 11:15 AM
FlyNavy's Avatar
Putting in Samco radiator hoses with a tubular manifold. Do I need to put some heat protection on the top one near the mani, or can it take it?
Old Jun 24, 2005 | 11:40 AM
marksae's Avatar
The advantage of using silicon over the stock rubber radiator hoses is that they don't dry up and become brittle as fast due to heat cycling, so they *should* last longer. However, having a tubular manifold next to the radiator hose is NOT good, as the thin-walled runners will transfer a lot more heat into the engine bay. I'd use the samco hoses AND thermal wrap.
Old Jun 24, 2005 | 01:27 PM
bolsen's Avatar
For what heat wrap costs, I'd think it'd be worth the investment to put it on for daily drving, if you pop the hood, pull it off
Old Jun 27, 2005 | 01:51 PM
FlyNavy's Avatar
Whats the least ghetto-looking thermal wrap option? Function over form of course, but curious what you guys were running. Thanks.
Old Jun 27, 2005 | 01:58 PM
bolsen's Avatar
I'll be running a custom made hard pipe...
Old Jun 27, 2005 | 02:08 PM
Zeus's Avatar
Do a search for my name and manifold... I had some pics up of some material I got from Lowes that seems to be the same stuff used to make casts for broken arms, legs, etc. I believe it is rated for 600 degrees.
Old Jun 27, 2005 | 03:11 PM
propellerhead's Avatar
Well, the silicone spatula I use in the kitchen is good for upwards of 500degF so I would imagine that purely from a heat resistance perspective the Samco hoses can probably handle the temperature. However, as folks have mentioned, the heat radiated from your manifold will get pretty high. It makes sense to heat wrap it. Personally I'm going to use some of the Thermo-Tec hose wraps that Jeg's.
tonyt
Oct 27, 2008 09:02 AM
Gleason at STM
16
May 16, 2008 10:05 AM
t51splbb
10
Feb 27, 2008 10:38 PM
signalauto27
Northwest Region
Jul 9, 2007 10:03 PM
Dr Evo
14
Jan 29, 2004 06:39 AM
