Just got new plugs: BPR7EIX
Old Jun 24, 2005 | 11:15 PM
yellowman's Avatar
Do I need to do anything before I put them in? They should be pregapped, right?
I ordered these specifically for the Evo, so I should just have to put them in???
Old Jun 24, 2005 | 11:17 PM
Evoisdream's Avatar
always gap ur plugs even if they are "pregapped" gap them put some antiseize on them throw em in
MrMejia's Avatar
yes, they should be pregapped to .26-.28. but double check (not with a round tool)
Old Jun 24, 2005 | 11:18 PM
bigjhoney's Avatar
They should be gapped at .028, which is fine. I like to check them to be sure, just be very careful because its easy to mess up the iridium tip.
Old Jun 25, 2005 | 12:19 AM
yellowman's Avatar
Are they pre gapped or not?? That's the question
NGK Iridium EVO Spark Plugs BPR7EIX
Product Description
Why NGK Iridium? More Durability and a Higher Melting Point compared to Platinum, better center electrode anti-oxidation and anti-erosion, improved ignition, superior anti-fouling, lower required voltage, new metal shell plating process for better anti-corrosion. One Step Colder plugs are recommended for car with 400+ hp Evo's
Fits: Mitsubishi Lancer Evolution VIII 03-05 GSR, MR, RS
Tech Tip: These plugs DO NOT come pre-gapped. We recommend purchasing the spark plug gapper tool, seen below. These plugs are one stage cooler then the stock EVO Plugs.
Old Jun 25, 2005 | 12:27 AM
TRDHarrier's Avatar
i have been told not to gap them because they r iridium. i just popped them in. TOTALLY forgot to put anti-seize but it shouldnt matter.
Old Jun 25, 2005 | 12:34 AM
badhabit90's Avatar
Cool
until you take them out......and the threads from the cylinder head go with the plug...
Old Jun 25, 2005 | 12:56 AM
TRDHarrier's Avatar
maybe i should go buy some anti-seize when i have to take my valve cover off to re-torque those head studs
Old Jun 25, 2005 | 09:43 AM
Evoisdream's Avatar
might as well anti seize is like 50 cents lol
Old Jun 25, 2005 | 09:49 AM
ty1243's Avatar
Sorry for my ignorant, but what is anti seize? Where do you buy the anti seize?
Old Jun 25, 2005 | 10:38 AM
TheBigLubinsky's Avatar
Where did you guys buy your plugs? I went to autozone and they didn't stock ngk's
Old Jun 25, 2005 | 10:52 AM
Evoisdream's Avatar
i had to get the NGK online only place i could find them anti seize u can get any local auto parts store its a small tear package and it makes it so the threads of things dont seize together so when removing them next time they dont get stuck and Tear ur engine apart... u can also use it on exhaust bolts etc just makes it possible to pull bolts out etc
Old Jun 25, 2005 | 11:05 AM
j8's Avatar
j8
Goto Napa they carry all the NGK plugs.
Old Aug 2, 2005 | 01:59 AM
TRDHarrier's Avatar
i went on ebay and bought the plugs. Costed me like 30 shipped.
Old Aug 2, 2005 | 02:56 AM
plokivos's Avatar
Why NGK Iridium? More Durability and a Higher Melting Point compared to Platinum, better center electrode anti-oxidation and anti-erosion, improved ignition, superior anti-fouling, lower required voltage, new metal shell plating process for better anti-corrosion. One Step Colder plugs are reccomended for car with 400+ hp cars. The colder plugs have non-projected tips, which lowers ignitability (if you need colder plugs, this shouldn't be an issue for you anyways).
Please Note:Iridium plugs are able to use larger gap setting with less voltage. Some customers choose to regap these plugs to correct misfiring or tune for optimal spark -- do so at your own risk -- slide-type plug gapper will damage the fragile iridium tip. Price is for One Plug Only.
