GReddy Profec B Spec II Boost Spikes - Need opinions
Old Jun 30, 2005 | 11:37 AM
Tsurara's Avatar
Right, so I have a Profec B Spec II. Im going to upgrade to an AVC-R or the EVC unit somewhat soon, but for now this sucker needs to work.
I run my car daily on a low boost setting (17-18psi) and I am getting boost spikes in 3rd gear. I typically spike to 1.3bar then settle to 1.15 to 1.2 bar.
Settings:
Set = 37%
Gain = 3
StartBoost = 1.10KPa
Warning = 1.60KPA
The odd thing is, I dont get boost spikes using my high settings which is like:
Set = 58%
Gain = 5
Warning = 1.60KPA
I have the third little cap removed and everything, any ideas what might be causing the spike?
Old Jun 30, 2005 | 12:07 PM
PVD04's Avatar
Your start boost setting is causing the spike. If you don't open the wastegate until 1.1 kpa, it won't be able to stop building boost by 1.15-1.2. Try dropping that down to 1.0 or so, that should get rid of the spike.
-Paul
Old Jun 30, 2005 | 12:14 PM
Tsurara's Avatar
-Paul
Oh jeez, good call. I didnt even think of this.
Thanks
Old Jun 30, 2005 | 12:31 PM
Randy's Avatar
You can set that gain to 10% trust me you will notice the difference
If you change it to psi here's what you need to do.
Set : 35%
Gain: 15%
Start Boost: 14 psi
Warning: 22 psi
IF YOU SET THE WARNING TOO CLOSE TO WHAT YOU WANT TO ACHIEVE IT WILL AUTO OPEN ITS SELENOID TO FULL DROPPING ALL THE BOOST.
Old Jun 30, 2005 | 12:34 PM
Tsurara's Avatar
Set : 35%
Gain: 15%
Start Boost: 14 psi
Warning: 22 psi
I thought that if you set the gain above 5 it starts spiking?
Old Jun 30, 2005 | 12:46 PM
Randy's Avatar
It doesnt
IF you do not put your set that high
Remember the Set on the profect B is how much you want your turbo to work, if you put 35% thats how it will build boost at 35% efficiency, BUT by using the gain at 15-18% you get that turbo to spool like a maniac, spikes happen when you forget to set the (Set Gain) Start Boost if you put it too close to the boost you wish to run then it will spike as the internal seleniod wont open in time.
Old Jun 30, 2005 | 01:16 PM
Tsurara's Avatar
Interesting! I will try this out for my high (autox) settings tonight on the way home from work.
arpad
179
Feb 9, 2020 03:51 AM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
J8dailo
May 30, 2007 05:49 PM
belizelittle39439
Mar 11, 2007 08:39 PM
arpad
Apr 12, 2004 08:23 PM
