In the middle of WR turbo install...got a question
Old Jul 3, 2005 | 01:08 PM
Zeus's Avatar
I've done many, and more and more by the day on Evos. However, I quote by the job, depending on mods... and I give you your car back looking like you brought it. No bent radiator fins, no rounded/over torqued bolts, with factory gaskets in place. These days, I see less and less quality work coming from "shops". They seem to like that "400ft lb torque wrench".
Old Jul 3, 2005 | 01:16 PM
EVO8LTW's Avatar
BTW, I took your guys advice and didn't remove the starter. Just retorqued the bolts and reinstalled the cover before dropping in the turbo. I was able to get the oil drain pipe without too much trouble with the starter in place and I don't think I'll have a problem with the IC pipe since I was able to clearance it with the turbo off the car.
Old Jul 3, 2005 | 01:44 PM
EVO8LTW's Avatar
Just got the new banjo bolt from a friend (thanks Memo!!) and the threads in the head are fine and the bolt is installed. What a relief! Gotta get back to work
Old Jul 3, 2005 | 08:17 PM
memo3's Avatar
Glad everthing worked out man...
can't wait for the results
Old Jul 3, 2005 | 08:32 PM
ries's Avatar
glad you got what you needed.......... let us know how everything turns out - cant wait to here how the new turbo performs
Old Jul 3, 2005 | 08:58 PM
EVO8LTW's Avatar
Done! Just have to wait until morning (i.e. neighbors) to crank it up and see if I have any leaks.
Old Jul 4, 2005 | 12:52 AM
IS2000's Avatar
A little off topic, but what parts are needed when swapping the turbos?
I saw these listed on the Forced Performance website.
GSCW Copper Crush Washers
GSOD Turbo Oil Drain Gaskets
GSTHIEVO EVO4-8 Turbine Inlet Gasket
GSTHOEVO8 EVO4-8 Turbine Outlet Gasket
GSTHEVO8bolt EVO4-8 Turbine housing inlet bolt
Thanks,
MitsuJoe
468
Feb 20, 2016 11:17 AM
halfnhalf83
31
Oct 7, 2015 08:23 PM
Jameson_IXMR
Jan 29, 2009 11:52 PM
Evoisdream
63
Jan 18, 2006 06:14 PM
MitsuJoe
Aug 1, 2004 01:59 PM
