2.2 stroker questions
I know the JUN 2.2 stroker kit is available.
Knowing this kit can spin to 9000 rpm, what allows this to be done at 2.2 and not 2.3? Is it the components of this kit? and if so, why couldn't you put this kit together yourself just by using components that make the JUN 2.2 kit?
Has anyone ever done this? Anyone know the 2.2 component specs for someone to try this? JUN 2.2 9000 rpm limit, while .1 more ltr would bring you down to 7500 rpm limit. What gives? Is it the bearings, piston wieght, rod specs? What's up?
I'm pretty sure the Jun kit has a much better rod/stroke ratio which allows it to rev higher. I also believe the Jun crank is forged.
Here is a good thread to read about revving a stroker engine.
I don't want to spend 6000 on something that could cost me 1500 total. I'm short a good 94mm crank. Has anyone bought just a forged 94mm crank to complete a 2.2 setup?
