Question about Karman reading
Originally Posted by justchil
I get about the same reading. Usually around 1700-1750. I think I've hit almost 1800 a couple times on race gas.
-Paul
ok i've been trying different things to try to figure out my low readings. i did a compression test and it said i had 180/180/185/178. i then took off the air filter just to see what it would read and it then only peaked at 1580. so no answers yet.
Just an update. I found that my AEM MAP was reading -1.1 with the car off, so I adjusted the calibration up by 1.1 psi and now it matches closely my Blitz ebc reading. Based on that (and carefully monitoring for knock) I'm now at what I think is ~20.5 psi (Defi D thinks it's closer to 22). I'm seeing up to 1950 hz on the MAF at ~7500 rpm with it about 80 degrees and humid with no knock.
