2nd gear grind
Old Jul 7, 2005 | 04:36 PM
termsheet's Avatar
2nd gear grind
Under WOT I have trouble getting into 2nd gear. It grinds for a second before it will go in. Anyone else have this issue?
Old Jul 7, 2005 | 04:38 PM
SIC SIK SIX's Avatar
happens to me too
Old Jul 7, 2005 | 04:39 PM
Vroompsh's Avatar
You're shifting too fast for the synchros to do their job, that is to smoothly shift from gear to gear. If you go faster than the synchro will work than either you need to slow your shifts down or your synchro is bad (or both!). For me it was both, and got the synchros replaced under warranty. if you shift slowly and this still happens, take it to Mitsu.
Old Jul 7, 2005 | 04:40 PM
i know my syncros aint bad yet, i only have 1900 miles
Old Jul 7, 2005 | 04:43 PM
an0ther's Avatar
sic its a common prob in evos. There are 2 ways to get by it. If you want to slam shift into 2nd, you can do it at 6600 rpm without grinding "usually" doesnt hurt performance since first dies off so quick and you will be at max torque when you hit 2nd. If you want to shift at higher rpms, when you hit 7500 or whatever, push in the clutch and wait 1/2 second before pulling it out of gear. Mine does this but I have learned to live with it and avoid it 99% of the time.
Old Jul 7, 2005 | 04:46 PM
Vroompsh's Avatar
^^ exactly and you really have to make sure you're shifting correctly and not just slamming gears, it can really hurt your transmission. BTW, Sic you car may very well have crappy synchros from the factory, why do you think i got mine replaced? There is a service bulletin on this problem specifically.
Old Jul 7, 2005 | 04:47 PM
i only tried to slam it in 3 times. i didnt want to keep on grinding the gears. for the most part, i just wait a split second like you said. i will try out shifting at 6600
Old Jul 7, 2005 | 05:07 PM
Turbo Meg's Avatar
This may sound stupid but I had the same grind going into second gear. I moved the seat up an inch or two closer to the dash and have not ground the gears since. Give it a try can't hurt.
Old Jul 7, 2005 | 05:16 PM
taenaive's Avatar
shift like ur grand pa. you will be fine. evo tranny really sux. I think mitsu should recall all of them.
Old Jul 7, 2005 | 09:00 PM
RalliArtEvoVIII's Avatar
what year is ur evo, 03 or 04? I tend to have this sometimes, and somtimes i completely misshift but this is due to my tranny having a leak somewhere :/
Old Jul 8, 2005 | 05:04 AM
90GSX-03EVO's Avatar
I've owned 2 different Evo 8's. I've ridden in many others. One thing I have noticed about my Evos compared to many others is that I never have had the 2nd gear grind in mine. Every friend who has asked me to drive their car to see if I could figure out why it would grind when shifting into second, I noticed the same thing on all of them: Exactly what you said. They had their seats a couple of notches too far back. They were all about the same height as me - give or take a couple of inches - but they would have the seat so far back that I couldn't even get the clutch all the way on the floor while sitting upright in the seat. Of course, I ended up grinding 2nd gear under hard driving, but as soon as I moved the seat forward, I never did again.....And neither did they after that.
Old Jul 8, 2005 | 05:21 AM
westchester evo's Avatar
There is a problem with the syncros. Mitsubishi has a fix. I had mine done and now can shift at 7,800 rpm no problem.
Old Jul 8, 2005 | 05:22 AM
Hiboost's Avatar
Seat adjustment does help reduce the chance of grinding 2nd but once in a While it still happens to me. Usually I'll get it while making a turn and trying to grab second relatively fast while cornering. Chances are the engine is moving around in it's mounts and making it tougher for things to lineup. I'm considering a shift kit and some stiffer engine mounts to head off this quirk, can anyone suggest what to look at?
Old Jul 8, 2005 | 05:49 AM
ray3328's Avatar
I think alot of us had this problem with second gear and all I can say is chances are it's driver error. I changed the way I shifted into second and haven't had a problem since so I came to the conclusion that it was me. You might want to try to engage the clutch fully before you begin your shift I noticed that I was shifting with my hand quicker than I was pressing down on the clutch. The Evo trans is not as easy to shift as others but it can be done correctly. My trans also needed till about 3,500 miles or so to shift smoother so I would suggest that people with low miles and this problem take it easy till it breaks-in.
Old Jul 17, 2005 | 12:57 AM
Thoe99's Avatar
This 2nd gear grind happens in my car too. It is NOT driver error, otherwise, I'd be grinding the other gears. I only grind 2nd, and it seems to happen daily now. My seat is pretty far up, ever since I had the car. I clutch all the way to the floor EVERY single time too. I'm sure if it was a problem with engine mounts, etc, the tuners' cars would be grinding all the time, since they have even more power to thrash the motor around (my car is stock). I say it is a factory defect.
