AFC Tuning for HKS 264/264?
Old Jul 8, 2005 | 10:47 AM
fuzzychi's Avatar
I just got a set of HKS 264/264 cams installed in my car (mods are listed in signature) and I wanted to know if I need to do any changes in my AFC from the Buschur Stage 1 settings. Also if I do need to change the AFC settings what would be the best way to go about getting in the right settings? Wideband o2? Datalogger?
Old Jul 8, 2005 | 10:55 AM
fuzzychi's Avatar
Old Jul 8, 2005 | 12:10 PM
Warrtalon's Avatar
Well, you shouldn't run an S-AFC without a loggind device to begin with.
Yes, you will need to make changes with the cams to compensate for the extra fuel, but it won't be as much of a change as if you added bigger injectors. You need to get a datalogger of some sort, preferably a wideband O2, then tune the car accordingly at both low-throttle (set the idle) and high-throttle (full boost/WOT). Do not rely on canned settings, because every car is different, and you have to compensate for local weather conditions (temp/humidity).
Old Jul 8, 2005 | 06:33 PM
fuzzychi's Avatar
bump bump
Old Jul 8, 2005 | 08:31 PM
Warrtalon's Avatar
bump bump
Ok, sorry, I won't answer next time.
Old Jul 8, 2005 | 08:39 PM
PVD04's Avatar
I'm not sure what you're looking for. The ONLY safe way to tune is with a logging device, preferrably a wideband. And yes, the cams will require different settings.
-Paul
Old Jul 9, 2005 | 01:21 AM
fuzzychi's Avatar
Oh sorry man I definitely didn't mean it like that, just wanted to more input and to keep the thread alive
fuzzychi
Jul 24, 2010 06:13 PM
binsquared
Apr 12, 2005 04:49 AM
PHILLY EVO
63
Feb 25, 2005 03:40 PM
megatron
Dec 10, 2004 09:06 PM
eclipse176
18
Aug 20, 2004 01:49 PM
