Big Trouble,,,engine died while driving....
Old Jul 16, 2005 | 12:59 PM
nastyevo8's Avatar
that sucks
Old Jul 16, 2005 | 01:14 PM
GREDDY's Avatar
CT9A, ensure your battery connection is tight. Take connections off and clean it then tighten it. This has caused many problems to my customers in the past. If everything else checks out good, have the alternator tested.
Old Jul 16, 2005 | 01:39 PM
CT9A's Avatar
Did all that already. Everything else operates fine, lights, radio, etc. My turbo timer even reads at >12v for system voltage. I haven't had the alternator checked yet. Maybe I'll do that.
Old Jul 16, 2005 | 01:52 PM
asasin79's Avatar
if you've recently removed the intake you may not have clicked the maf harness in all the way? happend to me a coupla times.
Old Jul 16, 2005 | 02:13 PM
CT9A's Avatar
I made sure that it was plugged in all the way. Thanks though.
Old Jul 16, 2005 | 02:28 PM
GOKOU's Avatar
Originally Posted by CT9A
Car cranks fine.
Here's my thought, tell me if this sounds right. I'm looking into power/grounding issues before the ECU. I figured that since the AFC isn't turning on, in addition to the Service Engine Soon light not coming on (with or without the AFC connected) I'm led to believe that the ECU isn't the problem, or at least not the ONLY problem. It seems to me that the ECU just isn't seeing power as the first problem.
Even if the AFC isn't allowing MAF signal to the ECU, as stated in a previous post, wouldn't the 12v power still come through and at least turn it on? I couldn't see the whole ECU shutting down and not coming back up because of a lack of signal other than 12v power. Right, wrong, maybe???
So car cranks fine but it won't fire? You smell any fuel trying to get there? Sparks?
The power to the ECU should be directly from the battery via fuses. SOme of the modules in the car have their own dedicated fuse. Where did you tap the power to the afc? Trace to see what happen to that power wire. SAme with the ECU if possible. If your car is still under warranty take it to the dealer.
Old Jul 16, 2005 | 02:29 PM
TriCycle STI C's Avatar
So the important question is...did you make it to the booty call or not??
Old Jul 16, 2005 | 02:35 PM
zlancer's Avatar
find the power wire that goes to the AFC and see if its getting 12v. Also find the wire going to the computer that is a constant 12v even with the key off. check your wires even if you think they are good. check your AFC ground. do a continuity check and see if it is a complete ground. also be careful when checking stuff. the ECU doesn't like to be spiked with a surge of voltage.
if you make the wiring back to stock and it still doesn't work make sure the computer is getting power from the constant 12v and the ignition 12v and has a good ground. if you have all of this then the ECU might have taken a crap on you. one of your wires make of shorted or something.
Old Jul 16, 2005 | 02:44 PM
BensLancer's Avatar
That sucks man! Hope you figure it out!! May be it was Karma telling you that that bootycall would have been a bad idea!
Old Jul 16, 2005 | 05:01 PM
EVIL MR's Avatar
is that all you think about?
I read this as: Subscribe to ****. Geez its been a long day.
Old Jul 16, 2005 | 05:26 PM
yokomo's Avatar
no I didn't, but about to go now
Old Jul 16, 2005 | 05:31 PM
dude's Avatar
You blew a 10 Amp fuse in your fuse box. Same thing happened to me, car just died while driving on the freeway. Would crank but not start. I checked the fuses but missed it the first time. Dealer found the fuse, replaced it and gave me a bunch of extra's, hasn't happened since...HTH
yokomo's Avatar
Talking
Originally Posted by SterlingEvo
sounds like a ground out or something related. The same thing happened to me way back when I first put on my exhaust and the o2 sensor was rubbing against the bottom of the car and the wires touched metal. Definitely re-check all of your connections and grounds. Especially if it seems to be affecting electrically a few select things in your car...
This is exactly what I think it is. I got home from work today and check my fuses. To my supprise, the ECM 20A fuse was blown. I changed it, headed for the parts store for more fuses when it happened again. So I finally made it to the store, popped one more fuse on the way home. Talked to my Pops, and came up with there is a short somewhere. Like SterlingEvo, I realized when I put on the CAt delete pipe, I saw the O2 wires press against the floor. Payed it no mind til today. So I taped up the wires and insulated them and I have to tighten up my exhaust.
But I think problem solved.
Thanx fellas for all of you alls input
Old Jul 16, 2005 | 05:33 PM
yokomo's Avatar
Sh*t I hope not
Old Jul 16, 2005 | 05:35 PM
yokomo's Avatar
The first thing I did when it stopped was pulled out the SAFCII. Didn't help. I got it out for now. and if nothing happens tonight, I'll put it back in.
This SH*T drove me nuts for a minute til I got a grip.
