Tech Tidbits
Old Feb 28, 2003 | 04:51 AM
Mike W's Avatar
Tech Tidbits
I've been digging in the EVO manual, some fun stuff. Here are a few things:
Description of the intercooler's water spray system
http://www.roadraceengineering.com/e...rsprayinfo.htm
Description of the variable fuel pressure obtained from jumping up the voltage to the fuel pump under higher engine loads
http://www.roadraceengineering.com/e...elpumpinfo.htm
ECU wiring diagram pinouts.
http://www.roadraceengineering.com/e...-ecuwiring.htm
The ECU uses the same plugs as the 2G Eclipse turbo. There are some differences. Hooking up an AFC will be the same as a 2G Eclipse. Some things I need to research a little more (A/C control and the water spray conections). The main differences that stand out are:
ECU monitoring of fuel temp and fuel levels. WTF?
Much more A/C system inputs/outputs
The fuel pump relay wire has moved from #8 to #22
An additional sensor ground (2 total now)
The interface with the Imobilizer ECU (anti theft thingy built into the ignition key)
AEM should have no problem coming out with the EMS for this car relatively quickly, but they will have to make a specific adapter board for it with the way some things have moved around on the plugs.
I am flying to Washington this weekend for a rally, I'll keep digging and updating as I have time.
Mike W
Old Feb 28, 2003 | 09:33 AM
Secret Chimp's Avatar
Thanks for posting this stuff! Interesting!
So can you tell if the ECU plugs are also the same they were in the previous EVO VII?
SC~
Old Feb 28, 2003 | 09:34 AM
LaNceRiTiZ's Avatar
...good infos..
Mike...
Nice status..!
Old Feb 28, 2003 | 10:08 AM
chronohunter's Avatar
Thanks Mike, Would you like to hint at some of the cool stuff you will have fro the EVO's and what kind of time frame
Old Mar 5, 2003 | 01:55 PM
EvoDaWayToGo's Avatar
Very interesting.... THanks alot for posting...
Old Mar 11, 2003 | 12:09 PM
indica's Avatar
great info. thanks for your research!
Mike W
84
Aug 19, 2016 08:36 AM
cky3396
124
Jul 6, 2012 04:02 PM
duck13
Evo X How Tos / Installations
Oct 19, 2011 08:06 PM
Mike W
Feb 27, 2007 08:37 AM
alainusmc
24
Sep 18, 2005 09:06 AM
