cams and fuel pump question -
Old Jul 27, 2005 | 10:02 AM
4-BNGR's Avatar
Ok, so I plan to do cams next (272/264 specifically) but I'd like to know if this upgrade will "require" doing a fuel pump upgrade... My car had been road tuned and the AFR's are where they need to be. Also, I run 21psi on my car (plan on keeping it there). I'm hesitant to buy the Walbro b/c 1) its mechanically loud and 2) it's been known to fail.
So aside from speculation and the "it's an $85 dollars insurance plan" can I run these cams on the stock fuel pump at 21 psi of boost on 93 octane pump fuel? Many thanks in advance...
Old Jul 27, 2005 | 10:05 AM
deadbeatrec's Avatar
u will get much better results with one then u would without one. its easy to do. just do it
Old Jul 27, 2005 | 10:14 AM
PHILLY EVO's Avatar
you cant even hear the fuel pump over the exhaust.....
Old Jul 27, 2005 | 11:19 AM
GTVEVO's Avatar
It isn't even really needed unless you are holding 21 psi to redline but when winter hits your injectors will pick up nearly 10% injector duty cycle due to the drastic temp drop on those cold days. That is when I would kind of worry about it becuase the stock pump could have issues trying to keep up. During the winter time on stock turbo and injectors with all the other upgrades I could go over 90% at 20 psi & 7000 rpms running a 11.1 afr on a walbro fuel pump via AEM log.
