Leaking Transfercase/Transmission seal
Old Jul 29, 2005 | 07:44 AM
Tsurara's Avatar
My transfer case had to be replaced. Long story not involving abuse, but someone else's negligence. In any case, the seal between my transfer case and transmission keeps leaking transmission fluid. They tried to replace the seal yesterday and it stopped leaking for the moment, but when I brought it back this morning, it was still leaking in the same spot (Right where the TC and transmission bolt to each other). Has anyone had this issue? What finally solved it?
This is an 05 Evo.
Old Jul 29, 2005 | 08:24 AM
nickracer9's Avatar
did they put the little oring that goes above that seal? not sure what goes through there but it seals up something.
Old Jul 29, 2005 | 08:50 AM
Tsurara's Avatar
Yes they did
Old Jul 29, 2005 | 09:36 AM
bolsen's Avatar
Wonder if they put enough grease around the ring, to seal it.
Old Jul 29, 2005 | 03:36 PM
j8's Avatar
j8
Sound like they are going to have to try again. I had the same problem and they were able to get the problem fixed the first time.
Old Jul 29, 2005 | 05:54 PM
marksae's Avatar
Is the o-ring getting pinched during reassembly? Lubing the o-ring should prevent it from moving around when you put it back together.
Old Jul 29, 2005 | 08:32 PM
Tsurara's Avatar
That's what I am wondering... I will have to bring it up next time.
Old Aug 1, 2005 | 07:38 PM
cliffsevo8's Avatar
my transfer case is leaking also but i took it to the dealer and they told me it would cost 90.00 to check the problem and then if it has pinched and they did not do it they wont fix it!!!!! he told me that it had to be a mistu defect befor they fix it. what should i do about this?
Old Aug 1, 2005 | 07:45 PM
cliffsevo8's Avatar
anybody?
Old Aug 1, 2005 | 07:46 PM
cliffsevo8's Avatar
Angry
help.....
Old Aug 1, 2005 | 07:59 PM
lookEVO's Avatar
tell them that NO MATTER WHAT it is their fault you idnt take it out. Or tell him to fnck off and try another dealer.
Old Aug 1, 2005 | 08:01 PM
cliffsevo8's Avatar
i pretty much told them that....i just took my keys and drove off
Old Aug 1, 2005 | 08:02 PM
lookEVO's Avatar
good job. call MMNA if they dont do it, if you're still under warranty there is no reason for that
Old Aug 1, 2005 | 08:03 PM
lookEVO's Avatar
or the BBB or whatever. someone that would get them to change their minds.
Old Aug 1, 2005 | 08:06 PM
cliffsevo8's Avatar
does it matter if i changes out my own clutch because somtimes they are **** about bolts being removed?
