need injectors for alky?
Old Aug 2, 2005 | 08:18 PM
Monkey's Avatar
Tried searching, but didn't get a great answer. You don't need new injectors if you run alcohol injection, correct?
Would I need anything other than what I have currently?
-turbo back
-intake and UICP
-boost controller
-walbro
-272s with cam gears
-headbolts
Old Aug 2, 2005 | 08:31 PM
mobounce's Avatar
You will need a flash of some sort or a piggyback.
Old Aug 2, 2005 | 08:45 PM
nothere's Avatar
I think you are right. with water or alky the motor should need less fuel.
Old Aug 2, 2005 | 09:11 PM
GTVEVO's Avatar
No you do not need injectors to run it. You injectors will run about 10-15% less once it is tuned so you will have even more room with them.
