whine-like noise from engine
Old Aug 3, 2005 | 09:15 AM
marmutz's Avatar
Question whine-like noise from engine
First, I'm not a engine expert so please bear with me. I have 05 MR. I heard this whine noise from the engine which distinct from other car. I'm not saying that this is an issue or problem. I'm just wondering where this sounds come from. I don't think it's from the turbo but maybe I'm wrong.
Thanks for the info.
Old Aug 3, 2005 | 09:21 AM
platinumspecv's Avatar
How many miles do u have on ur car? Can you describe the whine a bit more? As in when it happens .. what u are doing while it happens, which gear etc....
Old Aug 3, 2005 | 09:22 AM
Steven's Avatar
Under what circumstances do you hear this whine? Is it at idle or full throttle? I need some more details.
Old Aug 3, 2005 | 09:27 AM
marmutz's Avatar
I have about 8300 miles and I believe I can hear the whine even on idle. When on acceleration, I can't hear it since it is covered by the sound of the exhaust. Hope this info helps.
Old Aug 3, 2005 | 09:28 AM
marmutz's Avatar
oh... by the way, everything is stock except of the exhaust and TT. But the TT is off. The exhaust is Greddy Ti.
Old Aug 3, 2005 | 09:36 AM
Have you done any REALLY HARD launches lately?
Old Aug 3, 2005 | 09:37 AM
superman105's Avatar
Since it's all stock u should take it to the dealer
and have them deal with it
sounds like a boost leak to me
Old Aug 3, 2005 | 10:27 AM
marmutz's Avatar
update: When I just start the car, on idle, the sound follows the rev... I guess it's tranny? never did a hard launch. Like I said, I don't think it's a problem since I got no drivability issue. I'm just wondering where that sound come from.
Thanks for the inputs.
Old Aug 3, 2005 | 10:28 AM
anjapower's Avatar
whining from the TC at low RPM is normal...it sounds like that's what you're hearing, but then again, that only happens when you're moving...
Old Aug 3, 2005 | 10:32 AM
Steven's Avatar
You wouldn't hear the TC though at idle. It wouldn't make noise until your moving. It may be the throw out bearing. Try pushing in your clutch when you hear it and see if it stops or changes pitch.
Old Aug 3, 2005 | 10:39 AM
an0ther's Avatar
sounds like your tob, does it go away when you push in the clutch? My tob has been loud as hell since the day i got my car, all the way through the rpms. good news is its not tc since it does it at idle.
Old Aug 3, 2005 | 10:40 AM
marmutz's Avatar
Let me try pusing the clutch and update all of you. By the way, what's tob? Again, thanks for the input and info.
Old Aug 3, 2005 | 10:43 AM
marmutz's Avatar
Yup... The sounds disappear when I push the clutch. So it's TOB?
Old Aug 3, 2005 | 12:13 PM
WHTEVO's Avatar
yes it is your throw out bearing (tob) then. take it to the dealer and have them look at it.
Old Aug 3, 2005 | 01:07 PM
marmutz's Avatar
Any huge negative impact due to this whining TOB? Is this something that I need to worry about?
