Greddy R-Spec Intercooler
Old Aug 4, 2005 | 01:10 PM
Evo007's Avatar
I did some searches and couldn't find too much about this intercooler. Anyone running it and what are your thoughts on this intercooler? It looks really nice and is also larger than the V-Spec with a better fin system as well.
Old Aug 4, 2005 | 06:40 PM
Evo007's Avatar
Anyone?
Old Aug 4, 2005 | 10:25 PM
Derek888's Avatar
When I had mine installed I had a fully built race head done so hard to say what performance gains I got with it alone. Definately a nice piece and as for the fitment.. you have to trim your two front bumper mounts(inside the front bumper) a little bit and you get to keep your stock undertray. not sure how heavy the stock one weighs but the Greddy Rspl one is 12 lbs. I got pics of it close up and installed on the car if you want to see it.
Old Aug 5, 2005 | 05:38 AM
Randy's Avatar
Post those pics if possible
Old Aug 5, 2005 | 05:43 AM
Rmhaffa04's Avatar
+1
Old Aug 5, 2005 | 05:44 AM
Rmhaffa04's Avatar
I think factory weights 9.8lb
Old Aug 5, 2005 | 11:17 AM
Vapor's Avatar
Originally Posted by UMIAMI80.
From what I heard and searched about on this unit, it is actually worse then teh stock unit somehow. Again it is just hearsay.
Get an AMS unit or a Buschur Racing unit.
Arc is fine if you like expensive stuff.
You are confusing the RSPL with the VSPL, their more entry level i/c. The VSPL flows as well as the stocker (decent to 400hp), the RSPL is more for high hp applications. I have one on my 240sx and it did what it needed to do for me.
Old Aug 5, 2005 | 02:14 PM
Evo007's Avatar
Thanks for the info and the pics would be great. I was going to go ahead and get the R-spec because it was larger and had a better fin configuration. If I ever did a turbo upgrade I'd be covered.
Old Aug 5, 2005 | 02:16 PM
Thegame's Avatar
Is this a good choice for a stock turbo ic? Or would I be better off with AMS or Buschur?
Old Aug 5, 2005 | 11:40 PM
Derek888's Avatar
ill get some pics up in a day or two, still in Thailand on vacation. Its true what Vapor said, the R spec is built for high hp apps. Greddy and other JDM IC's like HKS, ARC...etc are tube and fin which are lighter than bar and plate.
Old Aug 6, 2005 | 03:14 AM
trinydex's Avatar
i'd have to say this is untrue... the vspec core is a piece... i hate hearing people say flowing a certain hp... cuz that's totally meaningless.
the rspec core is very well designed. it's got very nice fin design and it's very dense. the thermal transfer efficiency of this unit is probably unsurpassed by anything in it's weightclass. the only other thing close is the arc which is heavier and bigger. and as for efficiency bar none, the nisei would top both but is much heavier.
the rspec is a good match for the stock turbo but you should turn up boost and what not... yer not gonna see too much of anything but a drop if you just bolt it right on. cuz it's bigger than stock and prolly more restrictive too, but it's thermal transfer efficiency is better by far.
Old Aug 6, 2005 | 08:20 AM
Vapor's Avatar
Its not the same as on an Evo I realize, but its the same core
Old Aug 6, 2005 | 08:23 AM
Vapor's Avatar
air flow = HP, are you saying thats untrue? The VSPL has a lot of turbulators, which slow down the air, improving cooling, but limiting airflow. The RSPL has less turbulators so the velocity is not lost so much.
Also, the reason I said that was b/c that is how GReddy rates their cores.
cleanevo's Avatar
was that the v-spec core for the 240 , car looks good
Old Aug 6, 2005 | 08:34 AM
Vapor's Avatar
I have the RSPL core on my 240, thanks. It should be in Turbo next month
