Clutch peddle dead. Low brake fluid. couple questions
I picked up what was recommended on the cap. Dot 4. When I add this stuff should I bleed the exsisting fluid in the resevoir? and where should I bleed it from? any tips on doing this? I really dont want to get a bubble or mess this up.
Originally Posted by dafarmer69
is it leaking, did you find the leak.. are you sure there is no leak and the pressure plate isnt blown..
Would it leak if didn't drive the car all day becuase theres no puddle under my car right now.. how can I test it? How would I know if the pressure plate is blown?
Yeah, have you checked for leaks? Clutch pedal dead, low fluid sounds like a leak. Simply adding fluid won't fix it. Check the slave cylinder for the clutch, sometimes it can leak from there and not be noticed real easily, if the rod is off-center or the boot is torn...
yeayeaatou
Oct 31, 2013 04:56 AM
zstryder
Apr 10, 2012 06:04 PM
LaXGSR
Mar 23, 2010 04:23 PM
93civEJ1
Jul 19, 2004 08:18 PM
