spark plugs decision
Old Aug 7, 2005 | 09:37 AM
navysevo's Avatar
ok everyone i have a 2005 evolution 8 2800 MILES, with the following mods:
aem short ram intake
greddy type s blow off valve (single spring mod done)
hks 280 cams
greddy profec b spec 2 electronic boost controller @ 21 psi
megan racing EXHAUST::::
3" O2 housing
3" downpipe
3"cat delete pipe
3"cat back without the silencer
WALBRO 255 FUEL PUMP
PERRIN 02 SIMULATOR
turbo trix tune dynoed at 345 awhp and 300awtq
my question is i want to change the plugs and i already got the ngkbpr8es are they ok to put in and if not what plugs should i go with on this setup?
Thanks
Old Aug 7, 2005 | 09:43 AM
navysevo's Avatar
bump
Old Aug 7, 2005 | 09:45 AM
SlowCar's Avatar
why change so soon? the life for the stock iridiums just began!
Old Aug 7, 2005 | 09:46 AM
navysevo's Avatar
with the 100 hp over stock i thought it might be a good idea but maybe not
Old Aug 7, 2005 | 10:56 AM
Warrtalon's Avatar
I say to keep a set of NGK BPR8ES _handy_ in case you start experiencing any problems at full boost with the spark blowing out. If so, then swap 'em in with a .25-.26 gap. Until then, I'd keep on truckin' with the stock ones, since they're Iridium and will last a lot longer than the copper NGKs you got.
Btw, I am doing the same thing...I currently have a set of BPR8ES in hand if and when I need them, but I won't be changing them randomly.
Old Aug 10, 2005 | 12:21 AM
2.3EVO8's Avatar
im running them and like them alot better then stock
Old Aug 10, 2005 | 07:16 AM
Thanasi's Avatar
NGK that's what i run, but he is right why change
Old Aug 10, 2005 | 08:20 AM
revhappy's Avatar
What's the rule of thumb for the mileage to change NGK BPR8ES spark plugs?
Old Aug 10, 2005 | 09:27 AM
Warrtalon's Avatar
3-5k miles or whenever you change your oil?
Old Aug 10, 2005 | 09:46 AM
Soon2BEVO's Avatar
I replaced the stock Iridiums at 10k with NGK BPR7EIX (Iridiums).... Im still wondering if Im better of with copper NGK BPR8ES bc it seems many peole are running them with sucess?
Old Aug 10, 2005 | 09:51 AM
MIevo8MR's Avatar
Look into Denso iridiums. I believe they have plugs for racing application that run hotter.
Old Aug 12, 2005 | 10:46 PM
SR-71 BlackBird's Avatar
Registered User
you got cams and running in high boost better use the NGK Iridium IX BPR7EIX and gap it between .028 and .029 in.
Old Aug 12, 2005 | 11:22 PM
G20's Avatar
G20
The stock iridiums will run fine until about 430 whp (Dyno Dynamic) then you will need the NGK that you have and gap to .23 to .25 if you're making more power since you will experience the spark blowing out making your car shaking. I got the same problem and replacing the plugs with gapped cured it.
Old Aug 13, 2005 | 09:47 AM
revhappy's Avatar
What's the change intervals for the NGK Iridium IX BPR7EIX? How do they compare with NGK BPR8ES spark plugs
Old Aug 13, 2005 | 10:01 AM
Warrtalon's Avatar
BPR7EIX - Same-as-stock Iridium heat range "7" and last a long time (30-40k?) but fairly expensive.
BPR8ES - Copper one range colder (8) and last 5-10k miles depending on use and very cheap (<$2/pc).
