Upper IC Blowing off under boost
Old Aug 11, 2005 | 01:36 PM
RyanM's Avatar
I have the HKS upper IC and SSQV, anything over 21lbs blows the pipe off the fitting on the IC side. Looking for recommendations..
Adhesive?
Screw it on through the rubber?
Old Aug 11, 2005 | 01:38 PM
Cajun Power's Avatar
Try these....
Hair spray on the surfaces.
T-clamps.
silicone hoses.
Then if those don't work... maybe screw thru them both.
Old Aug 11, 2005 | 02:14 PM
mump's Avatar
what cajun said. I had the same problem and used hairspray. I want to get some t-bolts too but so far the hairspray is working great.
Old Aug 11, 2005 | 02:17 PM
Evoryder's Avatar
T-bolts...one of the greatest investments you can do for your car...
cost about 4 bux a pop...but they work...they really really work...
Old Aug 11, 2005 | 02:29 PM
RyanM's Avatar
How about a muffler clamp? I'm thinking its a combination of problems..
1. Hose clamping force is not sufficient at the upper IC joint
2. Engine torque moves the motor
Combined, the IC pipe overcomes the clamp in combination with the air flow.
I have the weapon-R torque damper, but haven't installed it yet. I will try that. I am going to pick up a muffler clamp, t-bolt and probably will hair spray the hose tonight as well.
I'm hoping Buschur has those motor mounts out soon, that will be great to have as well!
Old Aug 11, 2005 | 02:43 PM
Evoryder's Avatar
stop being a cheap *** ....just get the tbolt clamps and move on...maybe you're right about the motor vibration etc...tbolt clamp...vibration or not ...they aint coming off here are some visual aid for you: my tbolt clamps tbolts on an injen intake(for sale)
Old Aug 11, 2005 | 02:44 PM
bolsen's Avatar
or you can get someone to weld a big fat bead on the end of the pipe
Evoryder's Avatar
tbolts installed with custom upper hard pipe pictured
Old Aug 11, 2005 | 02:47 PM
Evilution VIII's Avatar
I had this problem on my first gen awd dsm, upper pipe blew off so hard it put a dent into my hood, LoL I know im not the only one that experienced that.
Old Aug 11, 2005 | 02:53 PM
RyanM's Avatar
Sucked to put back on a hot motor too, kept bumping my hand on the samco radiator hose and the IC Pipe was heat soaked.
I thought I was toast, 1.5bar of boost in 3rd gear hauling *** and heard a bang... then rolled over to side of road thinking a giant hole was about to be sucked into my wallet
I almost crapped myself, was so glad was just the IC
Old Aug 11, 2005 | 02:56 PM
Evoryder's Avatar
it's happened to many ... happened to me...thought i blew my engine or turbo...
always make sure you have a flashlight, couple of tools and a old tshirt in your evo...
Old Aug 11, 2005 | 11:02 PM
sleet's Avatar
^ I keep a rachet set in the back of my car with a towel and a flash light I need to get some of those t-bolt clamps where do they sell them? Autozone or anything?
Old Aug 12, 2005 | 12:06 AM
Jon H's Avatar
http://www.roadraceengineering.com/hoseandclamps.htm
RRE recommends their heavy duty clamps, that's what they use on their own cars without any problems. I have them on my car and with the alky, I've run 26-28 psi without them ever blowing off. They also carry the t-bolt clamps as well.
Old Aug 12, 2005 | 05:24 AM
RyanM's Avatar
I bought Samco fittings for the upper IC pipe last night from:
http://www.9secondracing.com/Mitsubi...anceparts.html
2 3/8 to 2 3/4 inch reducer for the Upper to IC connection
2 3/4 90 degree elbow for Upper IC to intake manifold connection
I wasn't able to find any t-bolts locally so I ordered Hose Techniques T-bolt clamps:
https://viewthewebsite.com/hosetechn...-Bolt%20Clamps
60267-33 T-Bolt Clamps 100% Stainless Steel T-Bolt Clamps x 1
60317-33 T-Bolt Clamps 100% Stainless Steel T-Bolt Clamps x3
Old Aug 12, 2005 | 07:36 AM
matt55's Avatar
NAPA has t-bolt clamps $3-4 each !
