halman mbc question..
Old Aug 14, 2005 | 10:34 AM
mump's Avatar
I use the same thing because my autometer gauge is a little off. I keep the blitz digital gauge at 1.48 which is right around 21.5 psi
Old Aug 14, 2005 | 11:14 AM
lightingyellow8's Avatar
how many turns did it take for everyone to get to 21.5 psi with their hallman? mines only boosting 20 psi and its 3/4 of a turn away from being maxed out.. im running it from the turbo nipple and the wastegate. whats wrong with it?
Old Aug 14, 2005 | 11:27 AM
Thegame's Avatar
Do you have the heavy spring in it? All hallman MBC's will boost the exact same when turned to a particular level with respect to boost source. In other words, after 5 turns of the hallman, my car will boost to the exact same level as yours. When Al was street tuning my car, he knew exactly where to put it without even checking it. He did the same on several other cars. It was pretty amazing to me. Al also doesn't recommend the RX as he says the ceramic ball in it isn't as good as the steel ball in the standard Hallman. I personally think the ceramic ball is better, as there really isn't any concrete proof as to the big difference in the two.
Old Aug 14, 2005 | 11:40 AM
evojon's Avatar
I would think, if for no other reason, the steel is more durable than the ceramic. the ceramic could shatter. 1 in a hundred thousand chance maybe, but?
Old Aug 14, 2005 | 11:51 AM
Jakeg97's Avatar
Originally Posted by JSYEVO
i have a blitz dc-ll trubo timer that has a boost gauge in it, it rads in bar though.
alright thanks for the info!
20.5 psi is just about 1.41 bar right?
one of your first mods should be a boost gauge, not an mbc
u need to be able to read boost accurately. a turbo timer isnt going to cut.
gl in not messing up your engine.
Old Aug 14, 2005 | 11:54 AM
kmcconn9's Avatar
definatly need a boost gauge.....
Old Aug 14, 2005 | 11:56 AM
mump's Avatar
actually the boost gauge in the blitz turbo timer is pretty accurate. when I was getting tuned by Turbo trix we tested both my blitz tt and my autometer boost gauge because they were about 1.5 psi difference. found out my tt was dead on and my autometer was reading high.
Old Aug 14, 2005 | 11:58 AM
kmcconn9's Avatar
true the boost gauge in the blitz turbo timer is accurate as I had one in my eclipse with an autometer boost gauge, but its just nice not to have to convert over from hkpa to psi...either way, some sort of a gauge is alot better than none...
Old Aug 14, 2005 | 12:53 PM
i have the hallman heavy spring but it isnt in the actual boost controller.. whats its purpose?
Old Aug 14, 2005 | 12:59 PM
bacalhau16's Avatar
i dont think that autometer boost guages are very accurate after a while. swap ur boost guages around with ur friends and notice the differences.
Old Aug 14, 2005 | 02:15 PM
JSYEVO's Avatar
al told me that the blitz dc-ll is gonna be pretty accurate, or else iwould have gotten a boost gauge first
Old Aug 14, 2005 | 10:48 PM
Jakeg97's Avatar
i prefer the quicker reading from a gauge, than from the lagging electronic signal.
autometer is a gauge that is known to have problems
buying a quality boost gauge (defi), and that would solve your high reading problem.
Old Aug 14, 2005 | 10:51 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=120185
Old Aug 15, 2005 | 10:07 PM
JSYEVO's Avatar
im going to be at 20.5 psi, should i put the heavy srping in?
Old Aug 16, 2005 | 12:53 AM
Jakeg97's Avatar
