halman mbc question..
Old Aug 13, 2005 | 12:44 PM
JSYEVO's Avatar
i just got my Pro RX kit, installing it monday. ok my question is how many turns should i start off with, im only looking to raise it to 20.5 psi. should i do this in 3rd gear? and remember this is the rx. thanks alot!
Old Aug 13, 2005 | 12:49 PM
SlowCar's Avatar
every car is different, start with minimum and bring it up from there. Go higher gear if you have road for it.
Old Aug 13, 2005 | 04:53 PM
4TUN8's Avatar
Like the previous person said, you should start it off on the lowest setting and run the car a couple of runs to warm it up. Start slowly increasing boost, I normally set mine in 3rd gear, but from what I've seen 20.5 psi in 3rd gear is going to push about 22 in 4th gear and even higher in 5th gear.
You can keep the car from doing this if you don't go from say 3krpm in 4th to WOT, it causes pretty severe spiking.
Get the car up to about 3500-4000rpm in 3rd and then floor it to see where you're at imo.
Old Aug 13, 2005 | 05:16 PM
SlowCar's Avatar
Put the MBC between the BOV and the wastegate instead of the turbo nipple/wastegate to get better response and less spiking.
Old Aug 13, 2005 | 05:59 PM
JSYEVO's Avatar
wow, this is gonna be harder than i thought, i dont konw a place to go 3rd or 4th gear besides the freeway lol. just pull to the side and go again? any ideas?
Old Aug 13, 2005 | 06:04 PM
mump's Avatar
yep. that is what you do. gun it in 3rd, watch boost gauge, pull over adjust, rinse, repeat as needed. find where you like in 3rd, proceed to 4thand 5th -- it should boost close to the same
Old Aug 13, 2005 | 06:35 PM
SlowCar's Avatar
another thing, try not to use the old tubing.....cant remember which one has "boost pill" in them. Use new tubing or if you have to recycle, check that there is no pill in them.
Old Aug 13, 2005 | 09:47 PM
Creamo3's Avatar
or you can purchase the adapter piece that allows you to control the boost from inside your car
Old Aug 13, 2005 | 11:08 PM
JSYEVO's Avatar
im not really understanding this? details please? lol
Old Aug 13, 2005 | 11:17 PM
sleet's Avatar
^ He means don't re-use the stock lines or anything because there is a stock soleniod in one of them which causes the boost to taper from 19PSI on stock cars. I'd go from 3rd gear and see what happens, just run the car with the lowest setting pull over and adjust, keep going untill you've reached your desired level of boost Have fun.
Old Aug 13, 2005 | 11:25 PM
JSYEVO's Avatar
oh alright, thanks alot! does anyone know appox how much psi it is for lets say half a turn or one complete turn?
Old Aug 14, 2005 | 01:01 AM
Jakeg97's Avatar
do you have a boost gauge?
Old Aug 14, 2005 | 06:29 AM
mump's Avatar
no. however, if your hallman is all the way off, you will only boost around 11psi, and it takes a couple complete turns before boost will go up. be patient and come to the understanding that you are going to pull over a bunch of times to get boost set where you want it. good news, once it is set you really don't have to touch it again.
Old Aug 14, 2005 | 10:15 AM
JSYEVO's Avatar
i have a blitz dc-ll trubo timer that has a boost gauge in it, it rads in bar though.
alright thanks for the info!
20.5 psi is just about 1.41 bar right?
Old Aug 14, 2005 | 10:20 AM
SlowCar's Avatar
Yep. 1psi = 0.069bar
