Why is my boost ramping up so slow????
Old Aug 18, 2005 | 07:27 PM
rraulston's Avatar
This is pissing me off. Look at the boost vs. rpm. Its SSLLOOWW to ramp up. Never used to be like this. I put on a Halman. I have a 3" CAT, could it be pluged?? Maybe the turbo is dying. The aircleaner is clean. Honkin boost leak???
Code:
 RPM	  MAP	  MAF	TPS
    	  psia	  Hz	 %
2440	-8.5	66	8
2447	-8.5	66	8
2450	-8.5	67	8
2427	-8.4	66	8
2190	-3	251	84
2204	-2.1	263	100
2252	-0.2	277	100
2337	0.7	289	100
2384	1	307	100
2465	1.4	322	100
2506	1.9	341	100
2575	2.2	365	100
2670	2.8	389	100
2736	3.3	411	100
2803	3.6	428	100
2881	4.2	469	100
2986	4.7	495	100
3075	5.4	531	100
3168	6.1	603	100
3242	6.9	614	100
3346	8	695	100
3486	9	783	100
3603	10.2	902	100
3732	11.6	1066	100
3889	13.7	1179	100
4065	16	1428	100
4246	18.4	1308	100
4444	20.3	1355	100
4616	21.4	1432	100
4768	21.7	1483	100
4938	21.9	1547	100
5128	21.9	1612	100
5282	21.9	1661	100
5446	21.6	1712	100
Old Aug 18, 2005 | 07:33 PM
Deepseadiver's Avatar
First check for boost leaks. Start at the air intake filter and go through all the hose clamps untill you reach the intake manifold. check all vacume lines as well. I hate boost leaks!!!! I've had the same problem and found a few loose clamps. I upgraded to better hose clamps from NAPA auto stores.
Old Aug 20, 2005 | 01:47 AM
Joey B's Avatar
Veteran: Air Force
Also make sure your boost controller is installed properly. I can't tell you how many ppl have installed one totally wrong.
Old Aug 20, 2005 | 05:33 AM
rraulston's Avatar
this datalog is without a boost controller. I mean the WG actuator is UNPLUGED. So the ramp up should be as fast as possible. Ime guestimating 3700 plus or minus 200 rpm for full boost. Ray
Old Aug 20, 2005 | 11:01 AM
use2vtec's Avatar
Did it start doing this as soon as you installed the Hallman or what? Do you have any logs you can compare it to before you did the boost controller? For a stock turbo the car is spooling really slow. It could be a boost leak or it even could be your turbo going out. Id start with a pressure check and see if you have any boost leaks.
Old Aug 21, 2005 | 02:32 PM
How do you unplug the wastgate? I am trying to find out why my boost is ramping up so slow and I think it might be the wastgate. Thats one thing I need to check.
How does the wastgate work??
The wastegate is right above the downpipe, and below the hotside right?
From the wastegate there is a arm that is connected to the wastegate actuator. The actuator has a vacume line running to the MBC.
Am i right so far?
I think my wastegate is open all the time. How do I fix it?
Evo442
Feb 8, 2007 07:41 AM
kapolani
Oct 9, 2006 05:50 PM
kapolani
Sep 19, 2006 05:34 PM
dudical26
Jul 18, 2006 10:32 AM
sgplancer
24
Jan 3, 2005 12:55 PM
