i need help!!! is it time to change bov?
i have s-afcII, greddy evo2, test pipe, k&n drop in filter, hallman mbc, and hks ssqv vta!!!!
i took out the ssqv and installed the stock bov....
1st, 2nd gear-like 14 psi
3rd,4th, 5th-25 pis!!
anything i done wrong, or should i buy the mr bov?
why did you put your stock back on??? your ssqv should hold boost fine. Is it just too loud for you??
I say put the ssqv back on either vta or recirc if you have the kit. If you didn't have a problem with it before, then it stands to reason that the stock bov is your problem (assuming you didn't install it wrong).
Originally Posted by lil'evil_evo
so all you did was change your bov and then this happened?
yup..tats all i did....u have any suggestions?
I recommend the MR one. It's cheap and does the job.
