Good lord, another tranny leak, but from where this time?? HELP!!
Old Sep 10, 2005 | 04:22 PM
IXMR's Avatar
well if it is light enough the seal surface could be buffed til it is a smooth surface again, if its real deep new axle shaft or some machine work (cnc type) if it is a light leak the retaining spring on the inside of the rubber part of the seal may have sprung loose during axle shaft install, it could be a lotof little things but brake cleen it first and make sure it is the seal, if you havent already fixed it
Old Sep 11, 2005 | 03:17 PM
93civEJ1's Avatar
ive already replaced the seal once, so thats what makes me think it from somewhere else...It isnt like a HUGE leak, but enough to dampen the case and under my car (not dripping)....
Old Dec 25, 2008 | 09:29 AM
RunThat's Avatar
bump! what was it?
Old Dec 26, 2008 | 07:40 AM
tc17's Avatar
yes, would also like to know. i have been told that people with quaiffe differentials have a problem locking in their axles to the stub shaft. then the axle rubs against the seal and damages it.
Old Dec 26, 2008 | 07:49 PM
1badgsex's Avatar
this info iam about to write dosent really sound like its near the area u are having problems with but hey ya never know could be possible i went nuts trying to figure out where my leak was coming from but eventually found it so all i can say is to atleast try these out. The thing is u have to separate/pull apart the t-case A LITTLE BIT to get to these o rings
well when i got my t-case rebuilt shep forgot put that large in size but small in diameter that goes on the "teethed" gear that slides into the tranny, also theres a really small oring that is for the acd and its really easy for it to fall out when trying to put the t-case in
MitsuJoe
468
Feb 20, 2016 11:17 AM
Hitmachine101
Oct 24, 2013 09:58 PM
yenny
21
Sep 12, 2012 11:28 AM
chassuter
Nov 18, 2009 11:41 AM
MitsuJoe
Aug 1, 2004 01:59 PM
