hks 280 dyno"s/numbers
Originally Posted by djskyy
I think it's a requirement if you want the FULL POTENTIAL of the cams....otherwise I'm pretty sure you can get away with the stock head...
Originally Posted by Soon2BEVO
Nothing to do with potential. THe valve springs/retainers and or lifters are needed for safety for higher revving. If he is going to 7500 stock head is more than fine.
Originally Posted by sleet
280s require any gears or anything? Or you just running them like you'd run some 272s?
Originally Posted by TTP Engineering
You can run them at zero/zero. It is a good setting for 280's. This same local went retarded (as in -neg) on settings and them switched it back to 0/0. I run a staggered retarded setting personally.
My theory is that the VE of the 4G63 falls off too much past 7000rpms to effectively utilize the longer duration, and advancing the intake cam brings the powerband of the 280s back down to where it can be utilized.
l8r)
It's interesting that such a tight LSA (106 deg) works so well in this application, but apparently the exhaust side flows well enough such that reversion isn't a problem. A larger turbine housing and tubular manifold (both of which I'm using) almost certainly enhances the result.
