how much gain out of upper and lower 2.5 ic pipes?
Old Aug 24, 2005 | 08:01 AM
BoostWhore's Avatar
I wondering what the adverage gain on upper and lower ic pipes are on a 320whp mustang dyno evo. I figure 8-10whp?
Old Aug 24, 2005 | 08:05 AM
AtO-MiX's Avatar
i would say 7-10 is about right...for lower ic piping..idk what upper ic pipe gives
Old Aug 24, 2005 | 08:10 AM
fromWRXtoEVO's Avatar
I improved 1 to 2mph trap speed on my Evo MR with the AMSlowerIC pipe and Buschur Deluxe Upper IC pipe.
This is not any coincidence, I take my MR to the track often and I use to trap 107mph on 91 oct before, since I did the IC pipes I am in the 109MPH consistently.
I can't tell much difference on spool up, maybe I don't have the 6th sense to tell that my turbo spools up a bit sooner but the fact is that my trap speeds improved significantly after I did the Intercooler pipes.
Fighters-garage sells a kick *** lower IC pipe, I suggest you call them, their IC pipe looks unbeliabeable.
my.2c
Old Aug 24, 2005 | 08:12 AM
AtO-MiX's Avatar
thos are some nice times
Old Aug 24, 2005 | 08:13 AM
Thanks, I appereciate it..not bad for a 3100feet elevation and 100 plus degree weather..
Old Aug 24, 2005 | 08:39 AM
anjapower's Avatar
I would say around 5whp and 5wtq...maybe up to 7/7, no more. I dynoed with my friend who had the same mods as me (only difference being the pipes) and he was a few whp higher.
Old Aug 24, 2005 | 10:46 AM
BoostWhore's Avatar
thanks for the input
Old Aug 24, 2005 | 11:33 AM
fsugatorbait's Avatar
Your friend also had a 264e cam to your 272.
Old Aug 24, 2005 | 12:39 PM
Noize's Avatar
EvoM Administrator
I added a lower IC pipe and an FMIC and gained maybe 2whp on the dyno in my car.
Old Aug 24, 2005 | 12:56 PM
anjapower's Avatar
compression numbers don't lie Too bad I didn't pop that BOV on before the dyno run
Old Aug 24, 2005 | 01:02 PM
haha...5 psi compression difference can be negated by the 10 degree temp changed from the morning, when you dynoed, to the afternoon, when I did. Put that in your pipe and smoke it.
Old Aug 24, 2005 | 01:06 PM
anjapower's Avatar
and the humidity went down on your run
we'll settle the score next weekend
Old Aug 24, 2005 | 01:36 PM
You got that straight hombre.
Old Aug 24, 2005 | 01:39 PM
What kind of FMIC do you have?, 2WHP improvement with a FMIC sounds ridiculous to me..
Old Aug 24, 2005 | 01:47 PM
anjapower's Avatar
better believe it...a friend with same mods as me (intake, cams, TBE, MBC, reflash) put down 7 more whp and 13 more wtq with: AMS Intercooler, AMS U/L piping, and Works TB.
