Gauge install!! Please help!
Old Aug 30, 2005 | 02:12 PM
nbpal4000's Avatar
i need to buy an adapter to use both senders..i dont think an inch of heat travel will..have a dramatic difference in reading temperature..
so either way i have to drain the coolant first??
Old Aug 30, 2005 | 03:15 PM
propellerhead's Avatar
The tee wont affect overall accuracy but it will affect the amount of time it will take for the gauge to read an accurate temperature. Also, I would strongly advise that you screw with the temperature sending unit for the gauge and not the one the ECU uses. Screwing with the sending unit that the ECU uses will definately affect the performance of your car.
You don't need to drain the entire cooling system. You can pull the lower radiator hose off and drain enough coolant to lower the level to the point that you won't be leaking (as much) coolant all over the place.
Old Aug 30, 2005 | 07:38 PM
nbpal4000's Avatar
hmm...if i dont have to drain the whole radiator...i might just use radiator hose adaptor to put sensor...u think thats better option than tee off? which one is less work??
Old Aug 30, 2005 | 08:55 PM
marksae's Avatar
The radiator hose adapter is definitely less work. Just cut the hose, and clamp the sensor on!
Old Aug 30, 2005 | 11:40 PM
nbpal4000's Avatar
what about the air bubble when u cut the hose?
Old Aug 30, 2005 | 11:58 PM
marksae's Avatar
Man, have you ever drained and refilled coolant before? After you put the hose back on, you refill the radiator with water/coolant til it's topped off. You then turn on the engine, let it warm up until the coolant starts to circulate (thermostat opens). When the water's circulating, top it off, and put the cap back on and you're done.
Old Aug 31, 2005 | 12:16 AM
nbpal4000's Avatar
i dont wanna drain the whole thing...i know there is a way without drainning the whole thing...
Old Aug 31, 2005 | 09:05 AM
LIFER's Avatar
OMG are you even listening to what they are saying?
Old Aug 31, 2005 | 09:48 AM
nbpal4000's Avatar
if u just drain the top part of the hose u dont have to drain the whole thing.
plus i just had my coolant flushed at the dealer....so i dont wanna drain again...
my friend told me theres a machin that will get rid of the air bubble..
Old Oct 22, 2005 | 09:24 AM
talentsearch301's Avatar
Hey guys maybe this is an option...
https://www.evolutionm.net/forums/sh...d.php?t=137387
I have samco hoses, Im trying to see if samco makes a hose like this also.
Good Luck
EmGee
Jun 26, 2015 10:53 PM
rraulston
21
Jul 25, 2006 11:57 AM
SuperHatch
Jan 23, 2006 07:36 PM
SzuChenEvo
13
Dec 28, 2003 09:25 AM
SzuChenEvo
15
Dec 20, 2003 02:19 PM
